How to integrate 1/(1+sin x)
  • Thread starter gona
    Integration
8 replies · 2K views · last reply
gona
Integrating [tex]\frac{1}{(1+sinx)}[/tex]
i just started learning Integration last week so not exactly sure how to approch this type of question.
no this is the first time i have seen where a trigonometric function is on the denominator
but now that i think about it
sinx = [tex]\sqrt{1-cos^2x}[/tex]
and arcsin was equal to [tex]\frac{1}{((1-x^2)}[/tex]
so i guess i could use the U substituition method
and then the answer would be...arcsin(cosx)? I am not too sure
No, no arcsin. But you might want to try multiplying numerator and denominator by (1-sin(x)). It may look more familiar.
You could also try the subsitution u = tan(x/2). It looks a little messy but everything cancels out.
well I am not sure if I am doing the right thing but here goes...
sinx = [tex]\frac{2tan(\frac{x}{2})}{1+tan^{2}(\frac{x}{2})}[/tex]
soo then i symplify the equation so that it is
[tex]\frac{1+tan^{2}(\frac{x}{2})}{1+tan^{2}(\frac{x}{2})+2tan(\frac{x}{2})}[/tex]
the i used u = tan[tex](\frac{x}{2})[/tex]
so i get [tex]\frac{1+u^{2}}{(u+1)^{2}}[/tex]
What should i do from here or is this the right way at all?
It looks to me like you are taking the long way around. Try multiplying numerator and denominator of your original problem by (1-sin(x)). You get (1-sinx)/cos^2(x). If you split that into two integrals you shouldn't have any problem with either of them.
Dick solution is quicker in this case but to integrate things like
1/(1+cosx+sinx) the substitution u=tan(x/2) is good.
But notice that it isn't x = tan(u/2) but rather u=tan(x/2). In order to get this into something the the example I gave you can show with so trig identities that if u=tan(x/2) then:
dx = 2du/(1+u^2)
sinx = 2u/(1+u^2)
cosx = (1-u^2)/(1+u^2)
If you substitue all that you the (1+u^2)s candel out and you get some rational function which you can solve with the typical rational function method (breaking it into elementry functions...)
wow by the way i got the answer using what dick said its actually pretty easy once u break it up...now I am going to try Daniels question going to see if i can get those now :) thnx a lot for the help by the way
the answe was tanx - secx +c
