How to Integrate a Function to Solve Air Resistance Equations?
7 replies · 3K views · last reply
Us477
I have been unable to solve this problem featured in "Elementary Differential Equations" by Edwards and Penney. The problem is this: I do not know how to integrate the function, and get the desired result. I would very much appreciated any help and instructions on how to get the two air resistance equations by integrating the function.
Thanks
Søren, Denmark
  • Handwritten-style derivation: dv/dt = g - (k/m)v^2 with k/m = p, the integral of u/(1-u^2) equals tanh^-1 u + C, v(t) = sqrt(g/p) tanh(t sqrt(pg)), and y(t) = (m/k) ln(cosh(t sqrt(kg/m))).
Thanks
Søren, Denmark
The ODE can be written with the variables v and t separated as...
$\displaystyle \frac{d v}{1 - \frac{k}{m g}\ v^{2}} = g\ d t$ (1)
... and remembering that is...
$\displaystyle \int \frac{d u}{1-a\ u^{2}} = \frac{\tanh^{-1} (\sqrt{a}\ u)}{\sqrt{a}} + c$ (2)
... You obtain...$\displaystyle \tanh^{-1} (\sqrt{\frac{k}{m\ g}}\ v) = \sqrt{\frac{k\ g}{m}}\ t + c $ (3)
... and from (3)...
$\displaystyle v = \sqrt{\frac{m\ g}{k}} \tanh (\sqrt{\frac{k\ g}{m}}\ t + c)$ (4)
Now You can proceed if You are able to find the constant c and that is possible if the initial speed v(0) is given... Kind regards $\chi$ $\sigma$
Thanks for your help.
I have a few questions for your solution -
1) Why are the position of the constants changed inside the radical in (3) – I am thinking they should be the same.
2) When I try to isolate ”v” I end up with a fraction - how did you go from (3) to (4)
I'm still new to all this thanks for helping me out
I apologize to have omitted some intermediate stage and I suggest You, as useful exercise, to try Yourself to complete my work...
Kind regards
$\chi$ $\sigma$
Yeah, I tried that but couldn't come up with your result. For your information, I use a N-spire calculator.
U477 said:
...for your information, I use a N-spire calculator...
Unfortunately I don't have available such a powerful math tool...
Kind regards
$\chi$ $\sigma$
So you have
$$\frac{1}{g} \, \frac{dv}{dt}=1- \frac{k}{mg}\,v^{2}$$
$$\int \frac{dv}{1- \frac{k}{mg} \,v^{2}}=g \int dt$$
$$ \frac{ \tanh^{-1} \left( \sqrt{ \frac{k}{mg}} \, v \right)}{ \sqrt{ \frac{k}{mg}} }=gt+c$$
$$\tanh^{-1} \left( \sqrt{ \frac{k}{mg}} \, v \right)= \sqrt{ \frac{k}{mg}}\, (gt+c)$$
$$\tanh^{-1} \left( \sqrt{ \frac{k}{mg}} \, v \right)= \sqrt{ \frac{k g^{2}}{mg}}\,t+\sqrt{ \frac{k}{mg}} \, c= \sqrt{ \frac{kg}{m}}\,t+c'.$$
Can you continue from here? Note that a constant times an arbitrary constant is just another arbitrary constant - in DE's, you often absorb known constants into arbitrary constants, and relabel as the original arbitrary constant. So the $c'$ above becomes $c$ again.
