How to interpret a complex Matrix as a Probability Matrix?
18 replies · 3K views · last reply
MaximeMusterFrau
Hello everyone,
I'have implemented a Maximum-Likelihood-Expectation-Maximization Algorithm in order to reconstruct a bild.
let say, we have such a system Ax=b, where A is a complex matrix, b is a complex vector.
A and b are known and we will iterately try to find the best x (which should be real) that fits that system.
The problem is taht the MLEM Algorithm is conceived to work for an A matrix that have real values between 0..1 (a probability matrix.). In my case, the A matrix is complex.
Does anyone know if this makes any sens ? How can I interpret my complex Matrix as a probability matrix?
I appreciate every suggestion :)
I understand that "bild" means "image". But I'm not familiar with what likelihood function is involved in the MLEM algorithm when the algorithm is applied to image reconstruction. Can you give a link that explains the algorithm - and how complex numbers become involved?
Wow, I didn't get this one, although the nick is a strong hint.
I think that what you are going after is something analogous to the CKM matrix or PMNS matrix in which the real probability of a transition is equal to the square of the http://www.regentsprep.org/regents/math/algtrig/ato6/absvlecomlesson.htm of the complex matrix element. But, it is honestly a bit hard to tell what you are getting at.
It also isn't clear if "bild" in your post is simply a misspelled "build" or has a specific meaning with which I am not familiar.
@ohwilleke @Stephen Tashi : Thank you very much for your answer. with bild I meant image, I am sorry. It is about an image-reconstruction algorithm.
http://ieeexplore.ieee.org/document/925290/
here is a link to a paper explaining what I am trying to do. In my case however, the c matrix is complex (which is no problem, as my image has to be real so I can just separate the real elements from the imaginary ones in my c matrix and just double the number of the rows )
My problem is that the elements of the matrix in my case can be also negative . So I am lookinbg for a way to make this algorithm work even for negative elements of the probability matrix. Can you help ? I have exhausted every idea I have..
I can only read the abstract of that paper.
Is the "c matrix" the matrix mentioned in eq 2, eq. 3 of the PDF:
ftp://kumulus.uzleuven.be/pub/nuyts/publications/jn_ieeetns99.pdf ?
This equation is a modiefied version of the one I am working on.
the C matrix is the one you find here :
https://arxiv.org/ftp/arxiv/papers/1504/1504.06889.pdf
it is the :probability of detecting an emission from the pixel j in projection’s bin i.
So my question is, what to do if some elements of C are negative ?
Thank you for your help!
I don't understand how an element of C (a probability) can be negative. Are you dealing with a different problem than the one described in https://arxiv.org/ftp/arxiv/papers/1504/1504.06889.pdf ?
I am dealing with a different image processing procedure. The matrix is measured and obtained from a FFT Transformation. And I am trying to find a way to transform the system (A x = b ) so that the the MLEM works.
In this case it doesn t work because the second derivative of the likelihood function is not always < 0 since the elements of A are not always positive.
So I was wondering if I could transform the system so it works ?
Before we consider procedure, we need to have the statement of the problem. What is the problem you are solving ? MLEM is often used to reconstruct 3-D anatomy from data collected by scanners. Is that what you are doing?
Where does probability come into play in the equation Ax = b. ?
"A" = matrix of complex numbers. Are these variables? - Is "A" the image ?
"x" = given data? - or is it variable?
"b" = given data ?
Are you trying to find the matrix "A" that makes "Ax" equal to "b" ?
the MLEM is supposed to work for Ax = b, where :
A: the probability matrix (it is given)
x: the image (which we are trying to figure out, real values)
b : given data (mesaered data)
In my case I have a system where A is not really a probability matrix, because it has negative values (they are measured so I can£t change them).
I wanted to adjust the MLEM Algorithm so that I can apply it in my case to find the image x.
Today I found AB-ML, which should consider the negative values, I implemented it in python but for some reason I can£t get the right result.
a link to the AB-ML : https://lirias.kuleuven.be/bitstream/123456789/485626/1/NEGML_TMI2014.pdf
Stephen Tashi said:
And I think this is the original AB-ML paper: http://faculty.uml.edu/cbyrne/byr98b.pdf
humm.. but I am a bit confused now.. because in the abstract it is cited that the elements of the system matrix also have to be positive. In the paper Pij>=0, which is equivalent to Aij >= 0 in the system : Ax = b .
In my case Xj >=0 but Aij can be positive as well as negative ..
Does this mean that I also can't use the ABML ?
Do you know which iterative algorithm alike MLEM or ABML I can use if my matrix A doesn't fulfill the condition of positiveness ?
I still have not heard a clear statement of the problem you are solving. You have only stated "Ax = b".
How does "Ax = b" relate to the paper by Byrne? Is "A" the same as "H" in that paper?
Yes it is..
Do the remarks in Byrne's paper "2. From general kernels to non-negative ones" apply to your problem?
okey, a more accurate situation:
we have
A =
[[ 5. 2. 3. ]
[ 0.4 0.1 5. ]
[ 5. 0.4 0.2]
[ 0.3 0.2 10. ]
[ 1. 0.3 2. ]
[ 0.3 0.7 0.4]]
b =
[[ 2. ]
[ 0.1]
[ 0.4]
[ 0.2]
[ 0.3]
[ 0.7]]
and we are looking for x that satisfies Ax =b .
In this situation the MLEM works very good and the x is found : [0 1 0]
now suppose we have an A, that is equal to :
A =
[[ 5. -2. 3. ]
[ 0.4 0.1 5. ]
[ 5. 0.4 0.2]
[ 0.3 0.2 10. ]
[ 1. 0.3 2. ]
[ 0.3 0.7 0.4]]
so we just took -2 instead of 2 .
b =
[-2. ]
[ 0.1]
[ 0.4]
[ 0.2]
[ 0.3]
[ 0.7]]
although there is a solution , which is [0 1 0], The MLEM doesn't work anymore and we are not able to find the x (because of the negative element -2 in A).
So my question is: if A has negativ elements, how can I transform the situation to find the x like in a MLEM Algorithm ?
I hope it is clear now :)
THANK YOU
The MLEM is to be seen in the picture uploaded, where aij are the elements of the matrix A and y is to be considered b in our case,.
The example still leaves the general problem unclear. Is your general problem to solve an "overdetermined" system of equations? - or to solve a system of equations that has a unique solution?
You example has 6 equations and 3 unknowns. But you've chosen numbers so the system has an exact solution.
If you are solving a system of equations that has a unique solution, you can transform the equations by doing "row operations" without altering the solution. For example: multiply row 6 by 10 and add it to row 1:
So ##(5. -2. 3.)## is changed to ## (5. +(10)(.3) ,\ -2. +(10)(. 7),\ 3. + (10)(.4) ) = (8., 5., 7.) ##
If you are solving a system of "overdetermined" equations, then a solution is defined as a value x that minimizes a certain measure of "error" between Ax and b. What measure of error are you using? Is it ##|| Ax - b||^2 ## ? - i.e. x the "least square error" solution ? The measure of error must be considered because a row operation might not preserve the solution.
