Undergrad How to know if a complex root is inside the unit circle
The discussion centers on determining whether complex roots of a quadratic equation lie inside the unit circle. The equation derived from the integral is z^4 + 2ikz^2 - 1 = 0, leading to roots expressed in terms of k. The participant confirms that if one root has a modulus greater than 1, the other must be less than 1, thus indicating its position relative to the unit circle. However, caution is advised when applying real number rules to complex numbers, as not all properties hold true in the complex plane. The conversation emphasizes the importance of verifying calculations and using polar coordinates for clarity in complex analysis.
dyn
Hi.
I have been trying to calculate the real definite integral with limits 2π and 0 of ## 1/(k+sin2θ) ##
To avoid the denominator becoming zero I know this means |k|> 1
Making the substitution ##z= e^{iθ}## eventually ends up giving me a quadratic equation in ##z^2## with 2 pairs of roots given by ##z^2 = i (+\sqrt{k^2-1} - k ) ##
and ## z^2 = i (-\sqrt{k^2-1} -k ) ##
The solution then states that"clearly the 1st two poles lie inside the unit circle and the 2nd two outside". This seems reasonable but how do I know for a fact that it is true ?
Thanks
The second is easy. ##|i(-\sqrt{k^2-1}-k)|=|\sqrt{k^2-1}+k|>|k|>1##. The first should be obtainable by multiplying the two.
Likes dyn
Thank you. Can I just check that I understand the rest ?
The quadratic equation in ##z^2## is ## z^4 + 2ikz^2 - 1 = 0 ##
The product of the 2 roots is αβ = -1 ⇒ |α|. |β| = 1
So knowing the modulus of one root is greater than 1 , means the modulus of the other root is less than 1
So that gives me , for one root ## |z^2| < 1 ## which also means for that root |z| < 1.
Have I got all that correct ?
Thanks
Thanks
That was the idea, but I cannot see what you have done. ##z## is confusing here, as you use the same letter for different numbers. You haven't mentioned the quadratic equation up to now, only the solutions. But if ## z^4 + 2ikz^2 - 1 = 0 ## is your equation, I get ##z_{1,2,3,4} = \pm \sqrt{-ik \pm \sqrt{1-k^2}}##. I see what you have done to write it as you did. However, one has to be careful with complex numbers. Not every rule which is valid in ##\mathbb{R}## is also valid in ##\mathbb{C}##.
See: https://www.physicsforums.com/insights/things-can-go-wrong-complex-numbers/
I would therefore check the following equations, just to be sure:
\begin{align*}
&z^4+2ikz^2-1=\\
&=\left( z- \sqrt{-ik -\sqrt{1-k^2}} \right)\left(- \sqrt{-ik + \sqrt{1-k^2}} \right)\left( \sqrt{-ik - \sqrt{1-k^2}} \right)\left( \sqrt{-ik + \sqrt{1-k^2}} \right)\\
&=\left( z^2- i\left( \sqrt{k^2-1}-k\right) \right)\left(z^2-i\left(-\sqrt{k^2-1}-k\right) \right)
\end{align*}
Set ##\alpha=i\left( \sqrt{k^2-1}-k \right)\, , \,\beta=i\left( -\sqrt{k^2-1}-k \right)## and then we have ##\alpha \cdot \beta = - \left( -\sqrt{k^2-1}^2 +k^2 \right)= -1## and then what you wrote.
Do you think I maybe applied a rule valid in ℝ which is not valid in ℂ ? To get the sum of the products I used the fact that for a quadratic equation ## ax^2 +bx + c = 0 ## with 2 roots α and β then αβ = c/a which in the above case is -1 (and I have seen this same result applied to complex quadratic equations)
I presume it is just a coincidence that the product comes to +1 or -1 as this helps make it easier to find out if the roots lie inside the unit circle and if the product is not +1 or -1 it just makes it harder to figure this out
I haven't checked, probably not, but that's why I said "make the control calculation" or make sure you can extract ##i=\sqrt{-1}## from the root. The best way to check such things is the representation in polar coordinates: ##z=re^{i\varphi}##.
  • · Replies 22 ·
  • · Replies 28 ·
