Graduate Creating a Variable Bend in a Function with Preserved Properties
  • Thread starter Thread starter Ad VanderVen
    Bend Variable
The discussion revolves around modifying a function, specifically $$y = s-1 + exp(-ln(-1/(s-1)) x)$$, to create a variable bend while maintaining the properties that for x = 0, y = s, and for x = 1, y = 0. A simplified version of the function is proposed as $$y = (1-s)^x + s - 1$$. A suggestion is made to incorporate a curvature parameter, b, leading to the function $$s-1+(1-s)^{x^b}$$, which meets the original criteria. The term "sub-exponential function" is discussed for naming this new function, though its appropriateness is questioned. The conversation emphasizes the importance of maintaining the function's properties while exploring variations in curvature.
Ad VanderVen
TL;DR
With a given function how to make a variable bend.
I have the following function: $$y = s-1 + exp (-ln (-1 / (s-1)) x)$$ with 0 < s < 1. For ##x = 0## you have ##y = s## and for ##x = 1## you have ##y = 0##. The function has a fixed bend, but now I want to make the bend variable, while the two properties, that for ##x = 0## you have ##y = s## and for ##x = 1##, ##y = 0##, should remain unchanged. How do I do that?
Likes Delta2
Where did you get that equation from? Do you realize it can be simplified to ## y = (1-s)^x + s - 1 ##? What is 'bend'? If you mean you want a similar function with an increased radius of curvature, try ## y = (1-s)^{x^2} + s - 1 ##, although that has a very different behaviour for ## x < 0 ##. How do you think you could modify this to get a curve that is similar for any value of ## x ##?
Likes Delta2
I want a similar function with the same restrictions as described above with a parameter, say ##b##, representing the curvature.
Have you looked at the function I suggested? How do you think you could incorporate the parameter ## b ## into it?
Yes, I looked at the function you suggested and the function $$s-1+(1-s)^{x^b}$$ with ## 0<b<1 ## would do perfectly. I cannot say how grateful I am..
What could you call such a function? Is it a special case of some well-known function?
I'm not a big fan of naming things: some people (and some educational cultures) get over-obsessed with naming and categorization.
I suppose you could call it a sub-exponential function (and for b = 0.5 a half-exponential function) but I have only seen this term used for increasing functions (i.e. ## s < -1 ##) so I think using that term in this context would not be helpful.
Likes jim mcnamara
@pbuk Anyway, thanks for the attempt.
  • · Replies 29 ·
