How to model converging illumination through object plane (in ZEMAX)
This discussion focuses on designing a projection lens system for a 35mm film projector using ZEMAX OpticStudio, specifically addressing the setup of converging illumination geometry in sequential mode. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, creating a converging cone with a 40.6-degree full angle. The goal is to maintain the same converging cone geometry at the relayed image while optimizing for image quality and light throughput. Key challenges include correctly modeling the illumination system and ensuring étendue conservation in the design.
  • Familiarity with ZEMAX OpticStudio software
  • Understanding of Köhler-type illumination systems
  • Knowledge of sequential and non-sequential mode design principles
  • Basic principles of optical relay systems and light throughput
  • Research the setup of Köhler illumination in ZEMAX OpticStudio
  • Learn about optimizing sequential mode designs for optical systems
  • Explore techniques for preserving étendue in optical relay systems
  • Investigate multi-configuration modeling approaches for illumination and imaging
Optical engineers, projection system designers, and anyone involved in the design and optimization of film projection systems using ZEMAX OpticStudio.
prrx
TL;DR
Designing 35mm projector relay for image rotator. Ellipsoid mirror creates converging 40.6° cone through film gate, focusing 40mm behind. Must preserve cone geometry and étendue. Unsure if Zemax sequential setup models this correctly.
Hello community,
I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging cone from the ellipsoid passes through the film gate, focuses at a point 40mm after the film gate, and then diverges.
The actual goal is to design a relay system that creates space between the film gate and projection lens for inserting an image rotator, while using standard projection lenses. The key design requirement is that the relayed image at the end must have the same converging cone geometry as the original film gate, so that a standard projection lens can be positioned at the correct distance from the relayed image with optimal light throughput. I need to preserve étendue through this geometry to maintain light throughput, but I'm unsure how to properly set this up in sequential mode to optimize for both relay image quality and throughput simultaneously. I can model the illumination system in non-sequential mode, but I don't know how to approach the combined relay and projection lens design where both imaging performance and étendue conservation are critical.
My current approach is to place the object surface at the film gate with field points defining the 35mm format, then place a stop surface 40mm after the object with a very small semi-diameter of approximately 0.1mm to represent the convergence point. I'm using Float By Stop Size as the aperture type with ray aiming enabled. However, I'm uncertain if this correctly models the converging illumination geometry for sequential mode design purposes, and whether this setup allows me to optimize for both image quality and light throughput.
Film projectors are standard optical systems, so I assume there's an established method I'm missing. Any guidance on the correct sequential mode setup for this Köhler-type illumination geometry would be greatly appreciated. I've attached a visualization of the complete setup showing the ellipsoid mirror, film gate, and convergence geometry.
Thanks!
Paul
Science news on Phys.org
In Köhler-type illumination Stop and Field apertures are exchanging between each other between two options, when taking light source or film as an object. The image also different for those two cases. Non-sequential mode is free of that "stop" and "field" conditions, but sequential mode is more powerful in optimization. I would try to build multi-configuration model with separate configurations and merit functions for illumination and imaging relay modes.
