How to obtain components of the metric tensor?
The discussion centers around the derivation of the components of the metric tensor in the context of the first post-Newtonian approximation. Participants explore the relationship between the metric tensor components and the potentials involved, specifically focusing on the definitions and implications of the potentials denoted as w and w^i.
  • One participant presents the line element in a specific coordinate system and questions how the quoted components of the metric tensor are derived.
  • Another participant expresses confusion over the lack of definition for the w functions, emphasizing the need for clarity in their roles.
  • Some participants suggest that the answer to the original question may be complex and reference literature that might provide insight, including IAU recommendations and works by Misner, Thorne, and Wheeler.
  • A participant mentions the approach of expanding perturbations in terms of a small parameter and discusses the implications of this method for deriving the metric coefficients.
  • There is a repeated emphasis on the need for definitions and explanations rather than just references to literature.
Participants express a lack of consensus on the definitions and derivations related to the w functions and the metric tensor components. Multiple viewpoints are presented regarding the complexity of the derivation and the adequacy of existing literature.
Some participants note that the definitions of the w functions are not clearly established in the discussion, and there are references to potential discrepancies in the literature regarding the definitions and their implications.
Matter_Matters
In coordinates given by [itex]x^\mu = (ct,x,y,z)[/itex] the line element is given
[tex](ds)^2 = g_{00} (cdt)^2 + 2g_{oi}(cdt\;dx^i) + g_{ij}dx^idx^j,[/tex]
where the [itex]g_{\mu\nu}[/itex] are the components of the metric tensor and latin indices run from [itex]1-3[/itex]. In the first post-Newtonian approximation the space time metric is completely determined by two potentials [itex]w[/itex] and [itex]w^i[/itex]. The Newtonian potential is contained within [itex]w[/itex] and the relativistic potential is contained with [itex]w^i[/itex]. What I don't understand is:
Often in the literature of the first post Newtonian approximation it is just quoted that the components of the metric tensor are given by:
[tex]\begin{split} g_{00} &= -exp(-2w/c^2), \\<br /> g_{0i} &= -4w^i/c^3, \\<br /> g_{ij} &= - \delta_{ij}\left( 1 +2w/c^2 \right). \end{split}[/tex]
How are these metric components derived?
I wonder why Van Hees liked the question but did not give a answer to it. :biggrin:
Would answering that question be too hard?
"Often in the literature" means nothing. What is the DEFINITION of the w functions?
Did you read the question?
As far as I can tell the answer is actually quite non-trivial. Which is a shame because the coefficients looks like a generalisation of the isotopic and harmonic Schwarzschild line element just incorporating two potentials.
It seems you made reference to w but did not define it.
You might try one of Norbert Straumann's books,
I'd assume the OP is talking about, for instance , the IAU 2000 recommendation B1.3, for instance, <<link>> or <<link>> Though there are some relevant updates to these resolutions - in 2006, I think?
From the first link, which is better formatted.
$$w^i(t,x) = G \int d^3 x' \frac{\sigma^i(t, x')}{\left|x - x' \right|}$$
There's also a defintiion for w, which is a bit more complicated, it has a second time derivative term but is otherwise rather similar to ##w^0##. I won't redo it here, this should be enough to locate it in the above links. I'm not really sure where this second time derivative term came from, exactly, by the way.
The above link tells us that s and ##s^i## are the gravitational mass and current densities, but I suspect they meant ##\sigma## and ##\sigma^i## were the gravitational mass and current densities :(. The second link is more official and doesn't seem to have this problem, but it's rather poorly formatted.
I regard these equations (and the reference presents them) as serving as a definition of the coordinate system, rather than explaining where they came from. The OP wants, I think, an explanation of where they came from, not just a statement of what they are. The IAU recommendations would be suitable for the former purpose (definition) but not the later purpose (understanding).
Misner, Thorne, Wheeler (henceforth MTW) has some discussion of where similar-looking (but perhaps not exactly identical) expressions are derived in their text "Gravitation". I'm not sure if it would be the best place to learn from - it's what I have, but I don't think the OP has it, and it's a bit old.
I'll just try to give some basic insight.
We start with ##g_{ab} = \eta_{ab} + h_{ab}## where ##\eta_{ab}## represents a flat-space Minkowskii metric, and ##h_{ab}## is "small" pertubation. Then we come up with the idea that we can expand the pertubation as a power series in terms of a small parameter ##\epsilon = M/r##, where M is the mass of some perturbing body, and the location of said perturbing body is treated as if it were in the flat space-time given by the metric ##\eta_{ab}##. I've written this as a single perturbing mass M, but we generalize from this to multiple perturbing bodies of mass ##m_i##, and then to perturbing mass densities - and mass currents, in the IAU approach, which seems to include more terms than MTW does. Applying the field equations to this and keeping "significant" terms, where "singificant" is defined by the order of the approximation, we have the direct approach of generating the PPN metric coefficients. One can be more clever about this and observe what the form of the metric coefficients might be, but I'm not going to try to be more clever in this short post. MTW talks a bit about how to be more clever, though.
  • · Replies 19 ·
  • · Replies 33 ·
