How to plot the simple pendulum phase diagram from the velocity-position equation
2 replies · 9K views · last reply
coverband
The relationship between velocity and position of a simple pendulum is given by the equation [tex]y= \pm\sqrt(2(C+\omega^2 cos x)).[/tex] The corresponding phase diagram is attached. How on Earth did they come up with the phase diagram. How do you plot such a complicated equation? Thanks
i'm guessing y is velocity and x is angle, or something similar
now consider starting trajectories along the y axis, this means starting at the bottom of the pendulum, with increasing velocity up the y axis. when the velocity is small, the trajectory is the normal back forth pendulum motion giving circle in phase space, however as the velocity is increased, at some point, there is sufficient energy for the pendulum to do full rotation and contiune, which gives the sinusoids with ever increasing angle.
try and consider a similar line of thought moving along the x-axis this time
The differential equation governing the simple pendulum is
[tex]m\frac{d^2\theta}{dt^2}= Lsin(\theta)[/tex]
where m is the mass of the pendulum, L the length of the pendulum (from the pivot to the center of mass), and [itex]\theta[/itex] is the angle the pendulum makes with the vertical.
That does not involve the variable t explicitely so we can use "quadrature". let [itex]y= d\theta/dt[/itex] so that [itex]d^2\theta/dt^2= dy/dt[/itex] and, by the chain rule, that is equal to [itex]dy/dt= (dy/d\theta)(d\theta/dt)= y(dy/d\theta)[/itex].
That is, the equation can be written as
[tex]my\frac{dy}{d\theta}= L sin(\theta)[/tex]
which is a separable equation:
[tex]y dy= (L/m)sin(\theta)d\theta[/tex]
and, integrating,
[tex]\frac{1}{2}y^2= \frac{L}{m}cos(\theta)+ C[/tex]
Solving for C gives the formula you have.
Now, as for graphing it, look at four separate possibliites for C. The left side, being a square, cannot be negative while the largest [itex](L/m)cos(\theta)[/itex] can be is L/m. If C< -L/M, the right side is always negative so the equation cannot be satisfied. There is NO graph for C<-L/M.
If C= -L/M, then for [itex]\theta= (2n)\pi[/itex], that is, even multiples of [itex]\pi[/itex], [itex](L/M)cos(\theta)- L/M= 0[/itex] but for all other values of [itex]\theta[/itex] are negative so the graph is a series of points [itex](2n\pi, 0)[/itex]. Those correspond to the pendulum hanging straight down. (Some textbooks show this on a cylinder with the angle going from [itex]0[/itex] to [itex]2\p[/itex] so there is just one such point.) This is, of course, a stable equilibrium position.
If -L/M< C< L/M. then the righthand side will be positive for [itex]\theta[/itex] 0 to where [itex](L/M)cos(\theta)- C= 0[/itex] which will be between 0 and [itex]\pi[/itex]. Of course, cosine is an even function so the same thing is true for y negative. That is, the graph will be a curve starting at (0, y) for some positive number y, then going down to (x, 0) for some x between 0 and [itex]\pi[/itex] and exactly the same thing between 0 and (-x, 0). Further, since the left side is [itex]y^2[/itex], that same behaviour occurs below the [itex]\theta[/itex]-axis. That symmetry produces a closed figure that looks like an ellipse or a circel (it is not either exactly). Those ovals are reproduced about every even multiple of [itex]pi[/itex].
Further, because y is the derivative of the angle, when y is positive, above the [itex]\theta[/itex] axis, [itex]\theta[/itex] is increasing so we might draw a small arrow to the right, and, below the [itex]\theta[/itex] axis, [itex]\theta[/itex] is decreasing so we might draw a small arrow to the right. The effect is to give a "motion" around the oval in a clockwise direction. That corresponds to the periodic motion with the pendulum swinging, with positive velocity, to the largest angle, then back the other direction. (In phase diagrams, closed paths are periodic motion.
If C= L/M, those Curves go all the way out to [itex]\pi[/itex] and connect with the next set of curves. At each point [itex]((2n+1)\pi, 0)[/itex], we have four curves, two with arrows pointing toward the point, two with arrows pointing away from it. These correspond to the pendulum being swung with just enough initial speed to reach the "straight up" position and stopping there. That is, of course, an unstable equilibrium position. At that position, any slight jar might make the pendulum swing down in either direction.
Finally, if C> L/M those curves never go down to 0- when [itex]\theta= \pi[/itex] (or any odd multiple of [itex]\pi[/itex], y= -(L/M)+ C, then increases again. Now the curves continue in both directions, above and below the axis, smoothly. Again, the "direction of motion", the arrows we put on each show motion to the right for y positive, to the left for y negative, now continuing in the same direction indefinitely. These correspond to swinging the pendulum hard enough that it gets to the top with non-zero speed and so continuse in the same direction. Since this equation represents no friction in the pendulum, it regains speed as it comes down and so just continues swinging in the same direction.
