How to Prove δ(cx) = (1/|c|)δ(x)?
The discussion focuses on proving the identity \(\delta(cx) = \frac{1}{|c|}\delta(x)\) for the Dirac delta function, specifically addressing the implications of the constant \(c\) being positive or negative. The proof involves changing variables in the integral representation of the delta function, leading to the conclusion that the absolute value of \(c\) is necessary to maintain the validity of the equation when \(c < 0\). The participants clarify the importance of considering the limits of integration during variable substitution, particularly when \(c\) is negative.
  • Understanding of the Dirac delta function and its properties
  • Familiarity with integral calculus and variable substitution techniques
  • Knowledge of differential equations, particularly second-order systems
  • Basic concepts of force and motion in physics
  • Study the properties of the Dirac delta function in greater depth
  • Learn about variable substitution in integrals and its implications
  • Explore applications of the Dirac delta function in physics, particularly in modeling instantaneous forces
  • Investigate the relationship between delta functions and distributions in mathematical analysis
Students and professionals in mathematics and physics, particularly those studying advanced calculus, differential equations, and signal processing, will benefit from this discussion.
Raze2dust
[SOLVED] Dirac delta function
Prove that \delta(cx)=\frac{1}{|c|}\delta(x)
For any function f(x), <br /> \int_{-\infty}^{\infty}f(x)\delta(cx) dx = \frac{1}{c}\int_{-\infty}^{\infty}f(t/c)\delta(t) dt<br />
where I have used t=cx.
<br /> =\frac{1}{c}f(0) <br />
This is fine and matches RHS for c>0. But how do we get the mod sign for c<0. Why isn't the above procedure valid for c<0 as well?
You have implicitly assumed that c>0 when you changed variables. Either that, or you forgot what else needs to be changed...
What happens to the limits of integration when you make the change of variable and c is negative?
thanks nrged!
wonder how it didn't strike me after pulling my hair off for one hour
Consider a spring-mass system with a time-dependent force f(t) applied to the mass.
The situation is modeled by the second-order differential equation
mx"(t) + cx0'(t) + kx(t) = f(t)
where t is time and x(t) is the displacement of the mass from equilibrium. Now suppose
that for t greater than or equal to 0 the mass is at rest in its equilibrium position, so x'(0) = x(0) = 0. At
t = 0 the mass is struck by an “instantaneous” hammer blow. This situation actually occurs
frequently in practice—a system sustains an forceful, almost-instantaneous input. Our goal
is to model the situation mathematically and determine how the system will respond.
In the above situation we might describe f(t) as a large constant force applied on a very
small time interval. Such a model leads to the forcing function
The Dirac delta function is a special kind of object - it is not a
function in the usual sense, although we sometimes think of it that
way. Basically, it can be thought of as the "function" d(x) such that:
d(x) = 0 for x <> 0
= Infinity for x = 0
and the "size" of the infinity is such that the integral of d(x) with
respect to x from a to b is zero if a and b are of the same sign, and
the integral is exactly unity if a < 0 < b. More precisely, it can be
thought of as the limit of a series of functions that get more and
more peaked near zero, and whose area is always unity.
It is always to be implicitly used inside an integral, even though we
carry out operations such as:
f(x) = d(x) + d(x-2) (when integrated, this has area 2)
f (t) = \left\{\stackrel{^{\frac{A}{\epsilon},}}{0,else} 0 \leq t \leq \epsilon
Here A is some constant and \epsilon is a “small” positive real number. When \epsilon is close to zero the applied force is very large during the time interval 0 \leq t \leq \epsilon
In this case it’s easy to see that for any choice of \epsilon we have
\int\stackrel{\infty^}{f (t) dt = A}
-\infty
k..thanx for the info Horbacz !
your welcome raze 2 dust. and by the way, I am only 13...
  • · Replies 31 ·
