ldanielrosa
- 15
- 2
- TL;DR
- I want to use a waste stream from another process to do things with tin
While reclaiming silver from scrap, I see that I will have plenty of copper nitrate as a waste stream. I've found some material on reclaiming this at . I see that this will convert it to copper sulfate as an intermediate step. I would like to divert some of this to dissolve tin from scrap pewter.
Once I have tin in solution, I would like to reduce it as fairly fine particles. Will ascorbic acid do the job on tin that it does on copper and silver? I would like to use a process similar to . I'm concerned that simple displacement with iron or aluminum will make particles that are too coarse and irregular. If ascorbic acid will not reduce tin, is there a relatively cheap and low toxicity agent that will?
