gary350
- 276
- 75
I have an idea that should work but I need some accurate numbers. If i mix 1 gallons of gasoline with 1 gallon of water then let is separate i should get approx 90% gas and 110% water that contains the alcohol. I think I can use less water but don't know how much less, 1 pint, 2 pints, 3 pints, etc without a lot of trial and error? Gasoline with ethanol is bad for the lawn mower and all small engines it screws up the carburetor they are not designed for alcohol. WHY do the factors not fix the carburetor problem so they work good with alcohol probably because they can sell more replacement engines bigger profit for the company. It is almost impossible to find a gas station that sells Ethanol free gas except farmers co-op they require a lot of red tape to make sure your not using their gas in your car.
I don't want to waste the alcohol I can burn that in my hobby jet engine less water I have the easier gas & alcohol are to separate. My jet engine runs good with 95% alcohol and 5% water.
Is there an easier way to remove alcohol from gasoline?
