- 19,865
- 10,851
I need to replace a light bulb. There is no side screw and it doesn't seem to easily rotate. Any ideas on how to remove it?
This discussion focuses on the challenges of removing a flush mount ceiling fixture, specifically those with a bayonet type fitting. Users recommend using a rubber mallet to tap the glass counterclockwise to loosen it, as it can become tightly secured over time. The conversation highlights the frustration many experience with these fixtures, suggesting that manufacturers may design them to be difficult to open. Ultimately, some users opted to replace their fixtures with more user-friendly designs for easier bulb replacement.
PREREQUISITESHomeowners, DIY enthusiasts, electricians, and anyone facing difficulties with flush mount ceiling fixtures and light bulb replacements.
You mean the inner glass part?Evo said:Did you try pushing up on it and then tilting it?
Yes.Greg Bernhardt said:You mean the inner glass part?
It's pretty snug, doesn't budge at allEvo said:Yes.
Zooby posted some interesting solutions.Greg Bernhardt said:It's pretty snug, doesn't budge at all
Off to the hardware store tomorrowruss_watters said:The glass spins: it is a bayonet type fitting. Unfortunately, yes, they get tight. While Evo's solution will certainly work, in seriousness, if you tap it counterclockwise on the edge with a rubber mallet, that should knock it free. The glass is pretty thick.
