How to show a set has measure zero?
6 replies · 7K views · last reply
Matthollyw00d
I'm not completely familiar with measures yet, but am trying to be. I'm trying to show a that a few sets in Rn have measure zero and am having difficulty showing this using countable covers with a total volume less than [tex]\epsilon[/tex]. Is there an easier way to show that a set has measure zero? If it's needed, I could give the problems that I'm working with. Any help would be appreciated.
The method you mention is really the only general one. If you give the specific sets you're working with I may be able to give a simpler method in that specific situation.
Show that Rn-1 x {0} has measure zero in Rn.
This is one of the ones I'm working on.
This one is easy using epsilon neighborhoods.
I'll expand on wofsy's comment a bit. You do use the open cover formulation on this one. Let [tex]\{ q_k \}_{ k = 1 }^\infty[/tex] be an enumeration of [tex]\mathbb{Q} \times \{ 0 \}[/tex]. Show that if [tex]\varepsilon > 0[/tex], [tex]\left \{ ( q_k - \frac{ 1 }{ 2 }, q_k + \frac{ 1 }{ 2 } ) \times ( -\varepsilon\ 2^{ - ( k + 1 ) }, \varepsilon\ 2^{ - ( k + 1 ) } ) \right \}_{ k = 1 }^\infty[/tex] is an open cover of [tex]\mathbb{ R } \times \{ 0 \}[/tex] with total measure less than or equal to [tex]\varepsilon[/tex].
EDIT: This proof works for showing that [tex]\mathbb{ R } \times \{ 0 \} \subset \mathbb{ R }^2[/tex] has measure zero. The [tex]n > 2[/tex] case is a straightforward generalization.
The way I did it earlier used
[tex]\bigcup[/tex]n=1[tex]\infty[/tex] [-n,n]n-1x{0} which is a countable cover of Rn-1x{0}. Then using the fact that a countable union of sets of measure zero also has measure zero, you can show that each set has measure zero and the rest follows. After reading a bit on it today, I feel like I have a much better understanding of it now.
