How to Show Inner Products in Quantum Mechanics Using Fourier Transforms?
7 replies · 4K views
v_pino
Given [tex](\psi_1, \psi_2)=\int dx \psi_1^*(x) \psi_2(x)[/tex], show [tex](\psi_1, \psi_2)=\int dk \phi_1^*(k) \phi_2(k)[/tex], where [tex]\phi_{1,2}(k)= \int dx \psi_k^*(x) \psi_{1,2}(x)[/tex] and [tex]psi_k(x)=\frac{1}{\sqrt{2 \pi}} e^{ikx}[/tex].
[tex]\psi (x)= \int dk \phi(k) \psi_k(x)[/tex]
[tex]\psi(x)=\int dk \phi(k) \psi_k(x)[/tex]
[tex](\psi_1 , \psi_2)= \int dx \left \{ \int dk \phi_1^*(k) \psi_k^*(x) \right \}\left \{ \int dk \phi_2(k) \psi_k(x) \right \}[/tex]
[tex]=\int dx \left \{ \int dk \phi_1^*(k) \frac{1}{\sqrt {2 \pi}}e^{-ikx} \int dk \phi_2(k) \frac{1}{\sqrt {2 \pi}}e^{ikx} \right \}[/tex]
[tex]= \frac{1}{2 \pi}\int dx \left \{ \int dk \phi_1^*(k) \int dk \phi_2(k) \right \}[/tex]
Is this correct so far? How do I proceed from here? It looks like a Fourier Transform with the 1/2pi. And I have two integrals within another one for the dx. Can I separate them some how?
on Phys.org
When you substitute in the integrals for [itex]\psi_1^*(x)[/itex] and [itex]\psi_2(x)[/itex], the [itex]k[/itex] in one integral isn't the same variable as the [itex]k[/itex] in the other integral. If you use the same variable for both, you're almost certainly going to confuse yourself. In this case, you can't cancel out the [itex]e^{-ikx}[/itex] factor from one integral with [itex]e^{ikx}[/itex] from the other.
[tex]=\int dx \left \{ \int dk_1 \phi_1^*(k_1) \frac{1}{\sqrt {2 \pi}}e^{-ik_1x} \int dk_2 \phi_2(k_2) \frac{1}{\sqrt {2 \pi}}e^{ik_2x} \right \}[/tex]
I have revised my equation above. But now that the exponents don't cancel, how should I proceed with this?
[tex](\psi_1, \psi_2)=\delta(k_2-k_1) \int dk_1 \phi_1^*(k_1) \int dk_2 \phi_2(k_2)[/tex]
Is the delta function equal to 1 in this case? And has the equation given in the problem [tex](\psi_1, \psi_2)=\int dk \phi_1^*(k) \phi_2(k)[/tex] combined k_1 and k_2?
The delta function depends on k1 and k2. You can't just pull it out front like that.
By using the delta function, you can perform one of the integrations. I suggest you read about the delta function to see how that works.
I obtained [tex](\psi_1, \psi_2)=\int dk_2 \phi_2(k_2) \int dk_1 \phi_1^*(k_1) \delta(k_2-k_1) = \int dk_2 \phi_2(k_2) \phi_1^* (k_2)[/tex] by using [tex]\psi(x)= \int dx' \psi(x') \delta(x-x')[/tex]
Is it correct? Thanks for the help once again.
