How to show non-negative tangents ?
  • Thread starter Thread starter ghostanime2001
4 replies · 2K views
ghostanime2001
1. Show that there are no tangents to the graph of [tex]f(x) = \frac{5x+2}{x+2}[/tex] that have a negative slope.
2. Determine the equation of the tangent to the curve [tex]y = \frac{x^{2}-1}{3x}[/tex] at x = 2
1. Our teacher told us not to use the quotient rule because it is not in our curriculum so please do not give me a solution using the quotient rule. Thanks.
What about using the product rule with the chain rule then? Use the fact that A/B=AB-1.
1. Or Perform Polynomial division on f(x), then its quite simple.
2. You need 3 pieces of information for a tangent - what are they?
for 1. don't i use inequality ? set the equation f(x) < 0 and solve for x if it can't be solved then u can conclude there are no points that can give me a negative tangent
If you solve f(x)<0, you will be finding all x for which the function itself is negative i.e. below the x axis. But that's not what you want to find, you need to show that the DERIVATIVE is never negative.
