How to Simplify and Compute a Polynomial Sum?
  • Thread starter Thread starter missusa
    Summation
10 replies · 3K views
missusa
write out the following sum and compute where possible
[tex]\sum 3[/tex] x =0 (x2 + 2x + 2)
is that clear?
do you mean
[tex]\sum _{n = .3}(x^2+2x+2) = ?[/tex]
when [tex]x=0[/tex]
Now where is the index [itex]n[/itex] in the expression to be summed over?
And where is your attempt to solution?
Malawi that doesn't make much sense either.
Missusa, if you can't write proper LaTeX, it's better to do it completely without. For example, write
"Sum from n = 1 to infinity of (e^(-n / 3) / n^2)"
Maybe OP means:
[tex]\sum^3 _{x= 0}(x^2+2x+2)[/tex]
is that clear?
Integral said:
Maybe OP means:
Is Integral right about what you mean? Then the sum, from x= 0 to 3 means you replace the "x" in x2+ 2x+ 2 by 0, then by 1, then by 2, then by 3, and add:
(02+ 3(0)+ 2)+ (12+ 2(1)+ 2)+ (22+ 2(2)+ 2)+ (32+ 2(3)+ 2)
Integral said:
Maybe OP means:
That's about the only way I see it making sense. Same as if the limits of summation were n = 0, 3 and x = n, an integer.
Thank you so much you two are very smart...I do appreciate your help. That is what I meant but I could not write it the way it was.
Thanks again,
Can I get some information about Endogenous Moeny: honrizontalism and structuralism??
Definitely not. Especially if you are talking about Levi-Strauss anthropological structuralism with gratuitous misspellings.
That would be better suited in another thread, either in other sciences or in the economic forums.
Ostensibly, such a disussion is found in one's macroeconomic textbook, or one can search on Google with the keywords. Nevertheless -
http://www.trincoll.edu/~setterfi/Horizontalism,%20Structuralism%20and%20Historical%20Time.pdf
Complexity, Endogenous Money and Macroeconomic Theory By Mark Setterfield
http://cas.umkc.edu/econ/economics/faculty/Fontana/Winter 2005/ROPE.pdf
