How to simplify expressions in Mathematica with log and exp in them?
6 replies · 4K views
Master1022
TL;DR
How can I get the expression ## log(exp(z)) ## to return ## z ## in Mathematica?
Hi,
This is a pretty simple question, but I am new to Mathematica so I am not sure if I am missing something obvious.
Question: How do I make the expression ## e^{log(z)} ## return z?
Attempt:
I have used all of the following combinations and all of them return ## e^{log(z)}##. Are there any tips people have? I have seen some people online use some elaborate functions, but I am just looking for a simple(r) solution.
[CODE title="Mathematica"]e^log[z]
E^log[z]
PowerExpand[E^log[z]]
Simplify[PowerExpand[E^log[z]]][/CODE]
Thanks in advance.
PowerExpand[] works for me. Be sure to capitalize Log , Exp and E !
In[1]:= PowerExpand[Log[Exp[z]]]
Out[1]= z
  • Wow
Out[1]= z
Oh wow, that does work! Many thanks. Do you know of any reason why using an upper case Log[] inside a Solve[] function could lead to an error, but then I changed it to log[] (lower case) and the error went away).
To answer I'd have to see how you set up your Solve[] statement. Can you share it?
@Master1022, in your first post you asked two different questions:
How can I get the expression ##\log(exp(z))## to return z in Mathematica?
Question: How do I make the expression ##e^{\log(z)} return z?
First off, is z a complex number? A variable named z is often used to represent a complex number, so if you use z to represent a real number, that can lead to confusion amongst readers.
Mathematically, ##\log(exp(z))## is always defined and is equal to z, but the opposite order in the composition may not be defined due to ##\log(z)## not being defined. If z is real, log(z) is defined only for z > 0.
If z is complex, the Mathematica documentation says this:
Log[z] has a branch cut discontinuity in the complex z plane running from ##-\infty## to 0.
