How to solve an unclear geometry problem — Counting line segments in a rectangle
The discussion revolves around solving a geometry problem involving a rectangle with an area of 120 and a height of 4. Participants clarify that the length of the base can be calculated as 30 using the formula length = area/height. The conversation shifts to finding the distance between points A and 48 on the horizontal base-line, with the correct approach being to simply subtract A from 48. The distance formula is discussed, but it is noted that for this specific problem, a simpler subtraction suffices. Ultimately, the correct coordinate for A is determined to be 18, although some calculations leading to this result are questioned for their relevance.
AgesPast
#1 I counted the line segments to divide by 120 by 8 to get 15, which is incorrect. I further exhausted my options by subtracting 48 from 120 to get 72. Then I divided 72 by 4 to get 18, but I'm still unsure if this is the correct answer.
Counting/Dividing
120-48=72
72/4=18
The solution appears too simple to be the correct to me.
Welcome to PhysicsForums. If the area is 120 and the height is 4, what is the length of the base?
And given the length of the base, what is A? :smile:
Likes Delta2 and Frabjous
If the height is 4 then the length should be 30. I am still unclear what A would be: 30/5=6. That can't be correct.
You have calculated that the length of the base is 30 from the function length=area/height. The length of the base can also be expressed as a function of A and 48. What is this function? You then set the two lengths equal to each other.
Likes AgesPast and berkeman
A(x)=15x-x^2
So, would this be 48=15x-x^2?
What is the distance between A and 48?
30?
Likes berkeman
Yes, but what is the equation for the distance between A and 48; i.e. what is formula for the distance between the two points?
caz said:
Yes, but what is the equation for the distance between A and 48; i.e. what is the distance between the two points?
(w^2+h^2)^1/2
So, (30^2+4^2)^1/2
Correct?
You are thinking about this wrong.
If A = 0, what is the distance between 48 and A?
If A = 1, what is the distance between 48 and A?
Remember that A is a point, not the area.
Oh, this is just in terms of units right?
So, for A=0 then just 48.
A=1, then ?
Do you know the distance between 2 points, (a,b) and (c,d)?
  • Sad
Likes althea_saile and AgesPast
Keep it simple. On the horizontal base-line, one end is at 48 and the length is 30, so where is the other end, where A is?
Likes berkeman
I plugged it into the distance formula (30,4) for x and (48,4) for y to get 18, but it wouldn't have occurred to me at all that I needed to go that far.
Likes berkeman
The distance beween 2 points is ((a-c)^2+(b-d)^2)^0.5
The left bottom quarter of the rectangle can be viewed as the point (A,0)
The right bottom quarter of the rectangle can be viewed as the point (48,0)
Plugging these in, the distance between the two bottom corners is ...
This is wh
Plugging those into the distance formula, what I got for A:
No, the distance is 48-A. This is the length of the base of the rectangle. Make sure that you understand how to calculate this. Set it equal to 30 and solve for A.
30=48-A
-18=-A
18=A
Well done, thanks.
Likes Delta2 and berkeman
Whew! :smile:
Likes Frabjous and AgesPast
Emphasis added...
As FactChecker said, keep it simple. The points in question are on a horizontal line, so to get the distance between them, just subtract the leftmost coordinate from the rightmost one. The formula above is much more general than what is required in this problem. IOW, no square roots are needed.
AgesPast said:
120-48=72
72/4=18
@AgesPast, you came up with 18 as the coordinate in post #1, but your result seems to be correct by accident. There is no logical reason you should have calculated 120 - 48 (the area minus a coordinate value), and then later divided by 4. I suspect that the answer to the problem was given, and you did some calculation unrelated to the problem to come up with that number.
Likes AgesPast
