How to solve for the point where a mass falls off a sphere in a magnetic field?
  • Thread starter Thread starter lylos
    Mass Sphere
The discussion focuses on solving the dynamics of a point mass sliding off a smooth hemisphere in a magnetic field, as outlined in chapter 2.4 of Goldstein's classical mechanics. The Lagrangian formulation is employed, with the equations derived from the Lagrangian \( L = \frac{1}{2}m(R^2\dot{\theta}^2) - mgR\cos(\theta) + \lambda(R-a) \). The critical equations of motion are \( mR^2\ddot{\theta} = mgR\sin(\theta) \) and \( mR\dot{\theta}^2 - mg\cos(\theta) + \lambda = 0 \). The discussion highlights the need for numerical methods to solve the second equation effectively, as the small angle approximation is deemed insufficient.
  • Understanding of Lagrangian mechanics and the principle of least action.
  • Familiarity with spherical coordinates and their application in dynamics.
  • Knowledge of Taylor series expansions and their use in approximating functions.
  • Basic proficiency in numerical methods for solving differential equations.
  • Study the application of Lagrangian mechanics in non-linear systems.
  • Learn about numerical integration techniques for solving ordinary differential equations.
  • Explore the implications of the small angle approximation in physical systems.
  • Investigate the dynamics of constrained systems using Lagrange multipliers.
Students of classical mechanics, physicists working on dynamics problems, and anyone interested in the application of Lagrangian methods to real-world scenarios involving motion on curved surfaces.
lylos
Consider a smooth hemisphere of radius a placed in the Earth's magnetic field. Place a small point mass on the top of the sphere and provide an initial small displacement as to allow the mass to slide down the sphere. Calculate the point where it falls off the sphere.
This is from chapter 2.4 of Goldstein.
L=T-V
\frac{d}{dt}\frac{\partial L}{\partial \dot{q}}=\frac{\partial L}{\partial q}
First, I followed Goldstein in using a coordinate axis that is centered at the bast of the hemisphere with z pointing to top of sphere. The resulting motion can be contained in the xz plane if we consider the initial velocity in y to be zero.
L=\frac{1}{2}m(\dot{x}^2+\dot{z}^2)-mgz+\lambda(\sqrt{x^2+z^2}-a)
When I transform this to spherical coordinates, keeping in mind that R is constant, I have:
L=\frac{1}{2}m(R^2\dot{\theta}^2)-mgRCos(\theta)+\lambda(R-a)
Which yields the following equations:
mR\dot{\theta}^2-mgCos(\theta)+\lambda=0
mR^2\ddot{\theta}=mgRSin(\theta)
R-a=0
Goldstein states that you would solve the 2nd then solve the 1st and you can then solve for lambda. I am wondering what trick you must use to solve for the 2nd equation. I feel that the small angle approximation won't work here. Please enlighten?
Hmm, good question. The taylor expansion may need to go a bit further for something analytical. If it were me, I'd just go to numerics! Let me see if I can find something about it and post back later. My compy is about to run out of juice.
We have:
Which can be rewritten:
mR^2\frac{d\dot{\theta}}{dt}=mgRSin(\theta)
We make the substitution:
\omega=\dot{\theta}
Such that:
mR^2\frac{d\omega}{dt}=mgRSin(\theta)
By chain rule:
\frac{d\omega}{dt}=\frac{d\omega}{d\theta}\frac{d\theta}{dt}=\frac{d\omega}{d\theta}\omega
Finally:
mR^2\frac{d\omega}{d\theta}\omega=mgRSin(\theta)
Upon integrating and replacing \omega with \dot{\theta}
You finally have:
\dot{\theta}^2=\frac{-2g}{r}Cos(\theta)+\frac{2g}{r}
Took me a while to find this trick. I wish I could have figured it out myself without having to resort to someone else's work.
