How to solve for v_o of this weighted summer circuit?
  • Context: Engineering
  • Thread starter Thread starter dla
    Circuit Summer
The discussion focuses on deriving the output voltage expression (v_o) for a weighted summer circuit using operational amplifiers. The correct formula for v_o is established as v_{o} = \frac{v_{1} R_{a}}{R_{1}}\frac{R_{c}}{R_{b}} + \frac{v_{2} R_{a}}{R_{2}}\frac{R_{c}}{R_{b}} - \frac{v_{3} R_{c}}{R_{3}} - \frac{v_{4} R_{c}}{R_{4}}. The negative signs for the last two terms are clarified as a result of the inverting configuration of the operational amplifiers in the circuit. Understanding the relationship between the currents and resistances in the circuit is crucial for accurate calculations.
  • Operational Amplifier (Op-Amp) fundamentals
  • Understanding of inverting and non-inverting amplifier configurations
  • Basic circuit analysis techniques
  • Knowledge of resistor networks and their impact on voltage output
  • Study the principles of inverting and non-inverting amplifiers in detail
  • Learn about the superposition theorem in circuit analysis
  • Explore the effects of feedback in operational amplifier circuits
  • Investigate the use of simulation tools like LTspice for circuit analysis
Electrical engineering students, circuit designers, and anyone involved in analog circuit design and analysis will benefit from this discussion.
dla
I am trying to derive the expression for v_o for this weighted summer circuit. I've attached the circuit diagram.
I get that the first op-amp output is just the total current x R_a, and then you take that output and find the current of R_b + current of v_3/R_3 and v_4/R_4 and multply all that by R_c to get the v_o, this is what I got
\huge<br /> v_{o} = \frac{v_{1} R_{a}}{R_{1}}\frac{R_{c}}{R_{b}} +\frac{v_{2} R_{a}}{R_{2}}\frac{R_{c}}{R_{b}} + \frac{v_{3} R_{c}} {R_{3}} +\frac{v_{4} R_{c}} {R_{4}}
However the answer says that the last two terms are negative, how come?
\huge v_{o} = \frac{v_{1} R_{a}}{R_{1}}\frac{R_{c}}{R_{b}} +\frac{v_{2} R_{a}}{R_{2}}\frac{R_{c}}{R_{b}} -\frac{v_{3} R_{c}} {R_{3}} -\frac{v_{4} R_{c}} {R_{4}}
output = -1[/size]x(total current x R_a)
The input goes to each OP_AMP's inverting input
Thank you! I get it.
