How to Solve Hinge Force Problems?
The discussion revolves around a physics problem involving a uniform rod hinged at one end, released from an angle with the vertical. Participants are exploring the dynamics of the rod, particularly focusing on the angular velocity at the lowest position and the normal reaction force at the hinge immediately after release.
  • Mixed
  • Participants discuss the application of static equations in a dynamic scenario, questioning the appropriateness of certain assumptions. There are attempts to clarify the relationships between angular acceleration and linear acceleration, as well as the correct usage of trigonometric functions in their equations.
There is ongoing verification of attempts and calculations, with some participants providing feedback on potential errors in signs and assumptions. Multiple interpretations of the equations are being explored, and while some guidance has been offered, no consensus has been reached regarding the correctness of the answers compared to an answer key.
Participants are adhering to forum rules regarding the provision of complete solutions, emphasizing the need for demonstrated effort before receiving full answers. There are indications of confusion regarding the conversion between coordinate systems and the implications of sign conventions in their calculations.
mmaismma
In the figure shown a uniform rod of mass m and length l is hinged. The rod is released when the rod makes angle θ with the vertical.
Find
A) The angular velocity of the rod at the lowest position.
B) Normal Reaction due to the hinge just after the rod is released
I have solved problem (A).
But I couldn't solve problem (B).
Here is my attempt:
mmaismma said:
Homework Statement:: In the figure shown a uniform rod of mass m and length l is hinged. The rod is released when the rod makes angle θ with the vertical.
Homework Equations:: Find
Here is my attempt:View attachment 254983
The equations you have written in part B seem to be statics equations, but the rod will be accelerating.
You are absolutely right. Here is my attempt. Please verify the solution.
You have a few sign errors.
Which ways are you taking as positive for at?
And which way does centripetal acceleration act? (But that error didn’t matter because it is zero.)
You also seem to have dropped the mg sin theta term in Ny.
The signs are denoted in this image. And I haven't dropped the mgsin theta term. Also the at is taken in the +ve y-axis side (i.e. along Ny).
mmaismma said:
The signs are denoted in this image. And I haven't dropped the mgsin theta term. Also the at is taken in the +ve y-axis side (i.e. along Ny).View attachment 255076
Ok, so at is positive up, but then which way are you taking α as positive, and what then is the correct relationship between them?
Wrt the mg sin(theta) term you have not underscored the line I had in mind. (This is an example of why the guidelines say not to post working as images. If you take the trouble to type it in it is much easier to refer to. Or you could number your equations.)
Look at the next two lines. Nothing missing?
Sorry. My bad. Here is my revised attempt. Please check.
\begin{align}
\Rightarrow F_{net}{}_{x} &=ma_x\nonumber\\
\Rightarrow mg\sin \theta - N_y &= ma_t \nonumber\\
\Rightarrow N_y &= mg\sin \theta - ma_t \nonumber\\
&= mg\sin\theta -m \times \frac {3g\sin\theta} {2l} \times \frac {l} {2} \nonumber\\
\Rightarrow \mathbf {N_y = \frac {mg\sin \theta}{4}}\end{align}
And obviously ##\begin{align}\mathbf{N_x=mg\cos\theta}\end{align}##
\begin{align}
Looks good.
haruspex said:
Looks good.
It doesn't match my anwer key. Probably the answer key is wrong. But can you ensure me if my answer key is wrong. Here is what my answer key says:
$$N_1=\frac{3mg\sin\theta\cos\theta}{4}\\
N_2=mg\left[1-\frac{3\sin{}^2\theta}{4}\right]$$
Same answer but using vertical and horizontal coordinates.
$$\begin{align}N_1&=N_y\cos\theta+N_x\cos\theta\nonumber\\
&=\frac{3mg\sin\theta\cos\theta}4+mg\cos{}^2\theta\neq\frac{3mg\sin\theta\cos\theta}4\nonumber\end{align}$$
mmaismma said:
$$N_1=N_y\cos\theta+N_x\cos\theta$$
That doesn't strike you as unusual?
What did't strike me?
Since I have got to the answer, You can now post the complete answer as per Physics forums rules.
Giving Full Answers:
On helping with questions: Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given. Complete solutions can be provided to a questioner after the questioner has arrived at a correct solution. If the questioner has not produced a correct solution, complete solutions are not permitted, whether or not an attempt has been made.
It would be most odd that in converting between coordinate systems you would use the cosine of the angle in both terms of the one equation. If you do the right conversions you will find your answer and the book answer are the same.
You are right it ain't striking me. I can't understand what are you trying to say.
What is the vertical component of your Nx, taking up as positive?
What is the vertical component of your Ny, taking up as positive?
They cannot both involve cos(θ). One of them must be sine. And I believe one of them is negative.
You are right my bad. But it still doesn't match my answer key:
##\begin{align}&N_x\cos\theta+N_y\sin\theta=N_1\nonumber\\&mg\cos\theta\times\cos\theta+\frac{mg\sin\theta}4\sin\theta\nonumber\\&\frac{mg(4\cos{}^2\theta+\sin{}^2\theta)}4\neq N_1\nonumber\end{align}##
I believe N1 is horizontal, so you changed the wrong trig function for that case.
You are right. Continuing previous equation:
##\begin{align}&=mg\frac{1+3\cos^2\theta}4\nonumber\\&=mg\frac{1+3-3\sin^2\theta}4\nonumber\\&=mg\frac{4-4\sin^2\theta}4\nonumber\\&=\mathbf{mg(1-\frac{sin^2\theta}4)}\end{align}##
And
##\begin{align}N_1&=N_y\cos\theta-N_x\sin\theta\nonumber\\&=\frac{mg\sin\theta}4\cos\theta-mg\cos\theta\times\sin\theta\nonumber\\&=\mathbf{\frac{-3mg\sin\theta\cos\theta}4}\\&=\text{answer in opposite direction}\nonumber\end{align}\\##
Thanks.
And
Thanks.
A couple of typos in the N2 path. Should have ended up with ##1-\frac{3\sin^2}4##
Yeah you are right.
\begin{align}&=mg\frac{1+3\cos^2\theta}4\nonumber\\&=mg\frac{1+3-3\sin^2\theta}4\nonumber\\&=mg\frac{4-3\sin^2\theta}4\nonumber\\&=\mathbf{mg(1-\frac{3sin^2\theta}4)}\end{align}
