How to Solve Second Order Differential Equations with Non-Constant Coefficients?
13 replies · 4K views
The Bob
Hey all,
I have an exam coming up and the pattern of questions seems to include some that I am stumped with.
One goes like this:
The second order differential equation
x2y'' - 6xy' + 12y = 0,​
has non-constant coefficients. Find the general solution by looking for a solution y = xn and finding a quadratic equation for n.
I would love to say "this is what I have done" but I just couldn't see anything. I tried substituting y = xn, y' = nxn-1 and y'' = n(n-1)xn-2 into the equation but that just doesn't help, so far as I can see. I need a nudge in the right direction.
Cheers,
The Bob (2004 ©)
What do you get when you substitute y=xn (and derivatives) into the equation? Why do you say that this won't help? I think that's the correct way to approach this question!
Show us what you get after making the substitutuons for
[tex]y = x^n[/tex] and its derivatives.
Ok, well... after substitution and messing around with powers, which is probably why I didn't see it going anywhere (at least), I get:
xn(n - 4)(n - 3) = 0​
I am assuming I would be correct to say that n = 4 and n = 3.
So y = x3 + x4 with the quadratic for n as (n - 4)(n - 3) = 0
How much of this is good and how much can you tell is guess work?
Cheers,
The Bob (2004 ©)
Cheers,
The Bob (2004 ©)
It's all correct. When you sub in y = x^n, since the differential equation has the form [itex]ax^2y'' + by' + cy = 0[/itex], the reduction in the power due to differentiations on [itex]x^n[/itex] are canceled out by the x^2 in front of y" and the x in front of y'. You can thus factor out the [itex]x^n[/itex] to get [tex]x^n(an(n-1) + bn + c) = 0[/itex], which you know is only true for all possible values of x if the quadratic in n is equal to zero. In the specific problem you mentioned, that's why n = 3, 4.<br /> <br /> And so, you get the solutions y = x^4 and y = x^3, and your general solution is a linear combination of them, [itex]y = Ax^3 + Bx^4[/itex].<br /> <br /> So it appears you knew what you were doing, you just weren't sure of it.[/tex]
You don't need to "assume" it. This equation must be true for all x. In particular for x= 1 which means (n-4)(n-3)= 0.
So y = x3 + x4
Youwere good up to this point! Any solution to a second order, linear, homogeneous differential equation can be written as a linear combination of two independent solutions. x3 and x4 are independent solutions. What does a linear combination of them look like?
Yeap, this entire step eluded me. Well it didn't but and it is annoying because when I looked at it first time I thought about doing somthing like this.
y = Ax3 + Bx4, although I have worked it through and it would appear that A and B are can be any constant.
Anyway cheers all,
The Bob (2004 ©)
Whilst I am on a role, I have another question before tomorrow.
Given that y = ex is one solution of the differential equation
(1 + x)y'' - (1 - 2x)y' + (x - 2)y = 0​
find the general solution.
What I have done is let y = uex, differentiate this and substitued in. Then I have let w = u' and got down to:
w'(ex + xex) + 3exw = 0​
The problem from here is that the way I have been told to solve it is to assume it is in the form:
y' + P(x)y = Q(x)​
which does not allow a solution, unless, again, I am doing it wrong.
Any pointers?
Cheers,
The Bob (2004 ©)
Keep in mind that e^x is never zero, so you can divide it out of your equation in w to get
[tex](1+x)w' + 3w = 0[/tex],
which is a linear first order differential equation that you can solve using an integrating factor.
dextercioby said:
I'd say it's better if you simply separate variables and integrate instead of calculating the integrating factor.
May I thank you both. Although I do not understand completely why you can simply divide through by ex because it is never zero, I can appreciate what is being said and, unfortunately for now, learn that bit parrot fashion.
After this division, I could see where the seperable equation was with more ease.
Cheers again :biggrin:
The Bob (2004 )
One serious problem you have with this is that ex is NOT a solution to that equation!
Apparently, from what you have below the equation is actually
(1+ x)y"+ (1- 2x)y'+ (x-2)y= 0.
What if instead of e^x you had had [itex](2+2x)w' + 6w = 0[/itex] or [itex](117 + 117x)w' + 351w = 0[/itex]? In each case you would multiply both sides of the equation by 1/2 and 1/117, respectively, to get rid of the common factor in each term. The same goes for e^x: You're multiplying both sides of the equation by 1/e^x = e^(-x) to remove those terms from your equation. Equivalently, you could just factor it out, like you do with the [itex]x^n[/itex] in your first problem, to get [itex]e^x((1+x)w' + 3w) = 0[/itex] and note that for this equation to hold for all x, you need [itex](1+x)w' + 3w = 0[/itex].
