How to solve these equation?I try but getting wrong answer
  • Thread starter Thread starter vkash
The discussion revolves around solving a system of equations involving ordered pairs (x, y). The original poster initially miscalculated the discriminant of a quadratic equation derived from the system, leading to confusion about the number of solutions. After corrections and suggestions from other participants, it was clarified that the correct approach involves substituting values back into the original equations to find specific ordered pairs. Ultimately, the conclusion is that there are two valid ordered pairs (x, y) that satisfy the equations, not an infinite number as initially thought. The participants express gratitude for the assistance in resolving the misunderstanding.
vkash
Question
Number of ordered pair (x,y)(for y not equal to zero) solution of this equation.
(x+y)+(x/y)=1/2
(x+y)(x/y)=-1/2
options:
(a) 0
(b) 1
(c) 2
(d) none of these {this is my answer}
My answer
from second equation (x+y)=(-1/2)(y/x)
putting this in first equation.
(-1/2)(y/x)+(x/y)=1/2
let y/x=t;
-t/2+1/t=1/2
=>t2+4t-1=0;
Discriminant of this equation is greater than zero so there will two values for y/x;
hence there can be infinite sets of values y,x that can satisfy this equation, so answer should (d) none of these..
But this is not correct where am i doing it wrong.
thanks!
please try to help.
Just a quick look and it looks like you've multiplied t by 4 rather then 2..? Does this help?
You are pointing out it?
-t/2+1/t=1/2
=>t2+4t-1=0;
Oh! sorry that's typo error:"
it will t2+t-2=0
But even after that same problem is there. It has discriminant >0; so there must infinite solutions...
Try solving that quadratic, y/x=t, so you will have two solutions to y/x. Try rearranging these solutions so you can put them in one of the equations.
it will t2+t-2=0
Now the equation is correct. You will obtain two values for t. You just need to insert them in anyone of the original two equations and substitute x for y/t and then each of the two values for t will give you an ordered pair (x,y). Thus, you will have not have an infinite number of ordered (x,y) pairs but only two.
vkash said:
Question
(x+y)+(x/y)=1/2
(x+y)(x/y)=-1/2
options:
(a) 0
(b) 1
(c) 2
My answer
let y/x=t;
-t/2+1/t=1/2
=>t2+4t-1=0;
thanks!
please try to help.
Why not set u = x+y and v = x/y, to get the system
u + v = 1/2 and u v = -1/2 ? After you know u and v you can get x and y.
RGV
solution of the equation is y/x=1 and y/x= -2 so all values where y=x &y= -2x should be satisfied. BUT why these two conditions are not satisfying the main two equations.
got confused?><?
did it required to find out the relation in x+y too?
RGV
excellent help but what's wrong in my work...
got confused?><?
I don't know; I did not check. RGV
got confused?><?
Finding the two conditions for y/x is only the first step in solving the original equations. With this step you did not find the solutions to the original equations yet, you just narrowed them down. By now, you only know that the solutions to the original two equations satisfy either y=x or y=-2x (and NOT that ALL the values which satisfy y=x or y=-2x are all solutions to your original equations, most of them aren't). To find the the solutions to the original equations, you have to first insert y=x in anyone of the two original equations and solve it in order to obtain the first ordered (x,y) pair, and then insert y=-2x in anyone of the two original equations and solve it in order to obtain the second ordered (x,y) pair.
Just return that equation in one of the first equation and you will found all solutions.
You can also see SOLUTION
Sorry for bad English.
EDIT: oh, i didn't see that @spf post
spf said:
Finding the two conditions for y/x is only the first step in solving the original equations. With this step you did not find the solutions to the original equations yet, you just narrowed them down.[/color] By now, you only know that the solutions to the original two equations satisfy either y=x or y=-2x (and NOT that ALL the values which satisfy y=x or y=-2x are all solutions to your original equations, most of them aren't). To find the the solutions to the original equations, you have to first insert y=x in anyone of the two original equations and solve it in order to obtain the first ordered (x,y) pair, and then insert y=-2x in anyone of the two original equations and solve it in order to obtain the second ordered (x,y) pair.
thanks spf..
that's genuine mistake i did.
actually just assembling equation together aways does not give answer.every step may add something new thing or may remove some answers.
getting answer on wolfram-alpha just a way to check answer..
Here i am concerned about mistake i did.
after all i understood my mistake from spf's tiny lecture.
thanks to all of you for helping me.
Glad that I could help. Thanks to Ray Vickson for the elegant alternative substitution and to Karamata for the nice visual presentation of the solutions with wolfram-alpha.
