How to stabilize voltage on a mV scale using a DC power source?
To stabilize voltage on a millivolt scale for calibrating a thermometer, a precision voltage source is ideal but can be costly. Constructing a solution using a DC power source is feasible by incorporating components like resistors and zener diodes, though these may not provide the best stability. A recommended approach is to use a voltage reference PMIC that outputs a stable voltage, followed by an instrumentation amplifier to scale it down to the desired 39.000 mV. This method ensures accuracy and reduces noise, temperature effects, and offsets. Seeking detailed tips from experienced individuals in electronics can enhance the construction process.
creetski
Hello,
I'm in the process of calibrating a thermometer/datalogger (Omega DP470) that uses a thermocouple type T (-200-350 deg. C range), and I need a DC voltage source that can feed a steady voltage of 39.000 mV. I believe at this point I can either purchase a precision voltage source that can feed a steady voltage on a millivolt (mV) scale, or manipulate/construct my own using my (0-20V) DC source.
The problem is that precision voltage sources are fairly pricey for such a task (~$1000.00), and I would rather construct something that can stabilize my voltage. I am able to dial down the knob on my current DC source to around 39.000 mV; however, it is obviously going to be noisy. Several people suggested putting some resistors in series and see if that would do it, while others have mentioned using zener diodes to maintain a steady voltage. I'm a little on the inexperienced side when it comes to EE and am curious if anyone out there has dealt with a similar situation? Any help or (detailed) tips are highly appreciated!
Thank you.
Get yourself a voltage reference PMIC (Power management IC). Let's say that you pick on that outputs 5V like this one from Texas Instruments. Follow that with an instrumentation amplifier which scales the 5V down to 39mV. Then you'll have an accurate 39mV with good immunity to noise, temperature, and offsets.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
