How to 'undo' mod, or solve equation with a mod.?
  • Thread starter Thread starter rsala004
To solve the equation a = x mod b for x, the general form is x = b*k + a, where k is an integer. If a range is specified, such as 0 <= lowerbound <= x <= upperbound, k must be adjusted accordingly to ensure x remains within this range. The discussion highlights that k can be zero or a positive integer, but excluding negatives may be necessary based on the context. Additionally, when dealing with quadratic equations like a = (x^2) mod b, the solutions depend on both x and k being integers, and specific conditions may lead to no solutions at all. Understanding modular arithmetic and its constraints is crucial for finding valid solutions.
rsala004
if we are given something of the form
a = x mod b
where we are given a and b ...how can x be solved for ?
what if we are given a range for which x has to fall within?
something like 0 <= lowerbound <= x <= upperbound
I have thought about this a little while i came up with that
x = b*k + a
with k a positive integer.. would generate all the possible solutions
is this correct?
can anyone guide me in right direction to solving this?
is this correct?
What about negative numbers? Or 0? For k.
You're definitely in the right direction.
is this correct?
Why must x be greater than a?
no no, i mean some other defined lowerbound and upperbound.
for example, 0 to 1000000.. otherwise i assume there would be endless solutions.
I guess in my case i want to exclude negatives from k (since my boundary is positive), and include 0.
I read some more and I found this :
[PLAIN said:
http://homepage.smc.edu/kennedy_john/MODULARRSA.PDF][/PLAIN]
Theorem 7:
If a = b(mod n), then b=a(mod n)
So i guess I can say go from a=x(mod b) -> x = a(mod b)
Is this correct?
1. a could be greater than b, so even if you want your x to be positive, k > 0 is too strict a condition.
2. Sure, x = a (mod b ) iff a = x (mod b). Remember that by definition, x = a (mod b) <=> b | x-a.
Is this correct?
x = kb + a where kb + a > -1 is your general solution based upon your condition that x is not negative. Of course k could be any integer including even zero or a negative number for these conditions to be met.
the actual problem I am trying to solve is a bit different .. but similar problem i think (?)
okay, so with these problem settings below
a = (x^2) mod b, 0 <= x < U < b
(U being some integer to represent x's maximum value)
I can try to solve for x by setting up
x^2 = b*k + a
and the solutions are when both x and k are integers.
ah i understand, since b wasn't specified to fall into any certain range :) , hm since we say now that it is always greater than x,
(I think I can) assume that k >= 0.
so is it right to think that there are 1 + FLOOR(b/U) solutions for x?
Bear in mind that there could be no solutions at all. For example,
x^2 \equiv 2 \pmod 4
has no solutions, since all squares modulo 4 are either 0 or 1.
You can check this wikipedia entry,
http://en.wikipedia.org/wiki/Quadratic_residue
