How to use parallel axis theorem?
To calculate the moment of inertia of a solid door about its hinge axis, the parallel axis theorem must be applied correctly. The moment of inertia around the center of mass (ICM) was initially calculated using the formula for a rectangular plate, but the chosen axis was not parallel to the hinge axis. To correctly apply the theorem, ICM must be recalculated for an axis that is parallel to the hinge. Alternatively, the moment of inertia about the hinge can be calculated directly, as this may be simpler than adjusting ICM. Understanding the relationship between the axes is crucial for accurate calculations.
asz304
A solid door of mass 37.80 kg is 2.30 m high, 1.70 m wide, and 2.53 cm thick. What is the moment of inertia of the door about the axis through its hinges?
I= Icm + MD^2
Icm = 1/12[M (a^2 +b^2 )] formula for inertia of a rectangular plate.
so I found Icm = 25.767 kgm^2 by doing Icm = 1/12 [ 37.80 kg ( 1.7^2 + 2.3^2 ) ].
and I'm stuck in doing the parallel axis theorem, and I'm not sure if my work above is right.
You need to find the correct CM axis to take the MOI around first (hint: the axis for ICM must be parallel to the final axis. You seem to have found an orthogonal axis instead).
I can't get what you're saying..
The parallel axis theorem states that the moment of inertia (MOI) around any axis (which would be your door hinge axis in your case) can be found by taking the MOI around a parallel axis that goes through the center of mass (CM) of the body (and then add the term you have written as MD2).
In calculating ICM the equation you used indicates that you have chosen an axis of rotation that is perpendicular to the height and width of the door, hence an axis that is not parallel to the hinge axis. And if it is not parallel you cannot apply the parallel axis theorem. Thus, you need to find ICM around a different axis that is parallel to the hinge axis.
Alternatively, you can find Ihinge directly. Using the parallel axis theorem only makes sense if find ICM is easier than finding Ihinge.
If you think about it, a door rotating about its hinges is like a rod rotating about one of its ends. 8D
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 28 ·
  • · Replies 21 ·
