LaTeX How can matrices be written in Latex with or without vertical lines?
  • Thread starter Thread starter basty
    Latex Matrix
To write a matrix in LaTeX, the simplest method is to use the pmatrix environment, as demonstrated with the code \begin{pmatrix} 2 & 6 & 1 \\ 1 & 2 & -1 \\ 5 & 7 & -4 \end{pmatrix}. For matrices that require vertical lines, a more manual approach is necessary, using the array environment with specific formatting. An example provided shows how to include a vertical line: \left( \begin{array}{rrr|r} 2 & 6 & 1 & 7 \\ 1 & 2 & -1 & -1 \\ 5 & 7 & -4 & 9 \end{array} \right). This method allows for greater customization in matrix presentation.
basty
How do you write a matrix such as below image in Latex, in this forum?
Normally, the easiest way to write a matrix is to use the pmatrix environment:
Code:
\begin{pmatrix}
\end{pmatrix}
\begin{pmatrix}
\end{pmatrix}
If you need the vertical line, you have to do the matrix "by hand," and it requires a bit more work:
Code:
\left(
\end{array}
\right)
\left(
\end{array}
\right)
Likes Greg Bernhardt
