hpc2016
- 3
The reactor length of 128 meters was determined based on the need for each parcel of water to receive a specific minimum solar UV radiation dosage to effectively kill bacteria. The design incorporates variable flow rates that correspond to the solar radiation levels throughout the day, ensuring that the total dosage remains sufficient. Key factors in this calculation include the inactivation constant, pipe diameter, and initial water quality, which collectively influence the reactor's dimensions and performance.
PREREQUISITESEngineers, environmental scientists, and water treatment professionals involved in the design and optimization of UV reactors for disinfection processes.
OK. I can't give you every last detail because they don't provide all the details. But, it goes something like this. Each parcel of fluid passing through the reactor has to receive a certain minimum solar UV radiation dosage. To do this, they vary the water flow rate so that, as the solar flux decreases, the flow rate also decreases in proportion. There is going to be a certain minimum value of the total pipe volume and surface area necessary to achieve the desired cumulative radiation dosage over all radiation conditions and associated flow rates. This determines the design of the reactor.hpc2016 said:Yes, also given the inactivation constant, the pipe diameter and the initial water quality.
