HP50G Trend Lines: Solve Absorbance vs. Concentrations Easily
  • Topic: Calculators
  • Thread starter Whalstib
    Lines
2 replies · 4K views · last reply
Whalstib
Hi,
I'm taking 3rd semester chemistry and we often have to take a series of for instance:
Absorbance vs. concentrations data.
Usually a series 5 experiments with the goal to have a spread sheet type answer. I use Excel or what ever I have handy just to find the y=mx + b value for "m".
I want to use my HP50G to accomplish this while in class.
I looked in the HP50G manual and there does appear to be a way to create trend lines but is not working for me. The examples are a bit more involved in the answers.
I have a feeling I'm doing something wrong in the chose of which menu to use... I know my inputs are correct and formatted correctly so either this isn't possible or as I said I'm starting out on the wrong foot.
here's what I've been doing according to the manual:
Stats > Fit data > Linear Fit
I enter the data in A column=x axis, B column=Y axis
Answers not in the format I need.
None of the other choses seem to get me there either..
is there a simple way to do what I'm attempting so I have this with me always?
thanks,
Whalstib
Actually All I'm after is a way to use a linear regression on a series of data points Y vs. X.
Any advise welcome.
Whalstib
Whalstib said:
Hi,
thanks,
Whalstib
STATS > FIT DATA
You should see a screen that shows [tex]\sigma[/tex]DAT, X-Col, Y-Col, and Model. Choose Linear Fit for the Model, and X-Col and Y-Col as 1 and 2, respectively. When entering data, make sure that the X values are listed in the first column, and the Y values are listed in the second column (as per your settings). Here's a sample data set:
(1,5) (2,10) (3,15) (4,20)
On the calculator, this should appear in the matrix editor as as:
1 5
2 10
3 15
4 20
Upon pressing OK, you should see:
[itex]0.+5. \cdot X[/itex]
Correlation: 1.
Covariance: 8.3333333333
This means your "m" is 5. and your "b" is 0.
