HSAB: Hard Soft Acid Base | Ferdinand's Curiousity
6 replies · 4K views
fairburn96
Hi guys, my name is ferdinand. I'm curious about HSAB, especially to predict where the reaction goes.
Exp: HI + NaF >>> HF + NaI
H is hard acid
I IS soft base
Na is hard acid
F is hard base, and
HF Is hard.hard
NaI Is hard soft.
The reaction will goes to right or left? And why?
And since hard acid like to bind hard base, why NaI formed?
Thank you...
Terima kasih.And how about the borderline? Is it count as hard or soft?
Chemistry news on Phys.org
Have you calculated the equilibrium constant? My quick look says the reaction goes to the left, as you suspect.
Borek said:
In water? Or a solid and a gas?
Good question. I assumed water. OP?
insightful said:
I assumed water.
Then it should go to the right, HF is a weak acid.
I used DeltaGf of (all aqueous at 25C):
-129 kcal/gmol for NaF
-71 for NaI
-12 for HI
-66 for HF
and got DeltaGrxn = +4kcal/gmol and using DeltaG = -RTlnKeq, got Keq = 1.2E-3 indicating left side reactants at higher concentrations than right side products.
Well, it depends on what your starting material is. Yes, in general the equilibrium is to the left, but if you add HI to the NaF solution, fluoride gets protonated and the shift is to the right.
