Calculating Hydrostatic Pressure Difference
The hydrostatic pressure difference is calculated using the formula ΔP = n*f/A, where f is 0.4 kcal/mol/Å, and the unit cell dimensions are 23Å x 19.9Å x 30.4Å. The number of water molecules in a 5.4Å thick layer leads to a calculated value of n = 1.37 x 10^-19 mol. The final pressure difference is determined to be 0.50 MPa after converting from kcal/m² to MPa using the conversion factor of 4184 N/kcal. The calculations are confirmed to be dimensionally correct, allowing for conversion to Pascal.
  • Understanding of hydrostatic pressure calculations
  • Familiarity with unit conversions, particularly between kcal and Pascal
  • Knowledge of molecular dimensions and volumetric calculations
  • Basic principles of thermodynamics related to pressure and force
  • Research the conversion methods between kcal/m² and Pascal
  • Learn about the implications of pressure differences in nanotube applications
  • Explore advanced hydrostatic pressure calculations in fluid dynamics
  • Study the effects of molecular dimensions on pressure calculations in nanotechnology
Students and researchers in physics and chemistry, particularly those focusing on fluid dynamics, nanotechnology, and thermodynamics. This discussion is beneficial for anyone involved in calculating pressure differences in confined systems.
greisen
Hi
I am to calculate the hydrostatic pressure difference - given by the
\Delta P = n*f/A
where f = 0.4 kcal/mol/Å. The unit cell has the dimension 23Å x 19.9Å x 30.4 Å and the number of water molecules are 5.4 Å in the z-direction with a molar volume of 55.5 mol/l.
I start by calculating the moles of water
n = 23Å*19.9Å*5.4Å*55.5 mol/l 1000 l/Å^3 = 1.37*10^-19 mol
Than I assume that the force is acting on the 5.4Å depth of water which gives a pressure of
\Delta P = 5.4Å*0.4 kcal/mol/Å*1.37*10^-19 mol /(23*10^-10*19.9*10¯10)m² = 6.47*10^-18 kcal/m^2
It seems a little strange and how to convert into Pascal? Any help or comments appreciated. Thanks in advance
1. Homework & Coursework is the correct place for this question (not the Chemistry subforum).
2. What is the context for all this?
3. Why have you substituted the depth, d=5.4A into the equation?
4. Once you make the correction in 3, you will find you have the correct dimensions to convert to units of Pa.
so this should be okay
0.4 kcal/mol/Å*1.37*10^-19 mol /(23*10^-10*19.9*10¯10)m² = 1.1988e-08 kcal/Å /m^2
and than convert this to Pa? Thanks in advance
I can't attest to the correctness of the calculation without knowing what the question is, but now it is at least dimensionally correct.
Hi
Sorry if it is bit unclear.
I should calculate the pressure difference with a nanotube and on water on both sides. So I will use the formula \Delta P = n*f/A where f = 0.4 kcal/mol/Å and the unit cell of the system is 23Å*19.9Å*30.4Å and the number of water is in the 5.4 Å thick layer with a molar volume of 55.5 mol/l. So I end up with this
\Delta P = 10^10 Å/m 0.4 kcal/mol/Å*1.37*10^-19 mol /(23*10^-10*19.9*10¯10)m² = 119.88 kcal/m m^2
which I convert to MPascal with 1 kcal/m = 4184 N
4184 m/kcal N * 119.88 kcal/m m^2 / 10^6 = 0.50 MPa
Does this seems correct? Thanks in advance
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 16 ·
