Hypergeometric function identity with c=a+b
  • Level: Graduate
  • Thread starter Thread starter nrqed
    Function
5 replies · 2K views
Through some calculations in a graph counting problem, I have checked that for many values of N (a positive integer), the following is true:
$$ \,_2F_1 [\frac{1}{2},-N;-N+ \frac{1}{2} ; z=1] = \frac{4^N (N!)^2}{(2N)!} $$
I would like to prove that this correct for arbitrary N, but I cannot find anywhere an expression for this particular combination of parameters (note that ##c-a-b=0##, which is very unfortunate as it prevents the use of one well known identity). I have checked Abramowitz and Stegun and several other sources. No luck. Does anyone know if this is true or if they have some good source of identities to recommend?
It is a result that follows very easily using identities available at the DLMF:
https://dlmf.nist.gov/
The starting point is 15.4.24 (http://dlmf.nist.gov/15.4.E24)
## _2F_1\left(-N,b;c;1\right)=\frac{{\left(c-b\right)_{N}}}{{\left(c\right)_{N}}} ##
where the Pochhammer symbols are ##(a)_N = \Gamma(a+N)/\Gamma(a)##. You then use a few identities for those symbols to get your result. I used 5.2.7, 5.2.6, 5.2.5, 5.5.5 and 5.4.6 (see https://dlmf.nist.gov/5) .
jason
jason
Wow,
Thank you so much! I had seen the equation given in 15.4.24 but I had not realized that one could define ##(-n)_n## as is given in 5.2.7.
Thanks!
jason
Hello Jason,
I am now obtaining many conjectured identities that I cannot find in the literature. These involve generalized hypergeometric functions ##\,_pF_q## with ## p > 2## and ## q > 1##. For example I get a relation between ##\,_4F_3## and ##\,_3 F_2 ## for a certain choice of parameters (my relation involves three different positive integers).
Do you know if there are tables of known relations between generalized hypergeometric functions? I have seen a couple on the Wikipedia page but that's all.
Thank you!
Besides DLMF, I would check Wolfram Mathworld online. In terms of books, Erdelyi's "Higher Transcendental Functions" volumes 1-3 are legally available online:
http://numerical.recipes/oldverswitcher.html
They probably have a few relations.
I suspect that you don't have access to a library these days, but if you do then there may be other books to look at. For example, Yudell Luke's books "The special functions and their approximations" vol 1-2, and "mathematical functions and their approximations" should have some interesting information.
jason
jason
Thank you again, Jason. I appreciate it.
