MHB Hypothesis Testing: Wrong Critical Z Score Explained
The discussion focuses on hypothesis testing, specifically addressing critical z-values for left-sided and two-sided hypotheses. For a left-sided hypothesis in question (2), the critical z-value is typically -1.645, and the test statistic must be more negative than this value to reject the null hypothesis. In question (3), which involves a two-sided hypothesis, the correct critical z-values are ±2.5758, corresponding to an alpha of 0.01 divided by 2. The confusion arose from using incorrect critical values of ±2.33, which are not applicable for the specified alpha level. Clarifications on the critical values resolved the issues presented in the questions.
yelenaaa13
It looks as if question (2) asks about a left sided hypothesis.
The critical z-value should then typically be $-1.645$.
Where did you get the test statistic z?
To reject the null hypothesis, we need that the test statistic z is more negative than $-1.645$.
In question (3) we have a 2-sided hypothesis.
It means that we need to find the critical z-value for $\frac \alpha 2=0.005$, which is $\pm 2.5758$.
What is your problem with question (3)?
Thank you for your response!
I got the test statistic from this formula: ((p-hat - p)/(square root((p(1-p))/n) ( i attached an image of the formula i used since this is kind of hard to read).
It was cut off, but p-hat and n were given. p-hat is 0.75 and n = 90.
And my problem with question 3 is the z critical values. It says 2.33 and -2.33 are wrong, but on the table those are the values that correspond with an alpha of 0.01
Question 3 has a 2-sided hypothesis. We need the values that correspond to alpha/2=0.005.
Question 2 has a left-sided hypothesis. You probably need a minus sign in front of the critical z-value.
Question 3 has a 2-sided hypothesis. We need the values that correspond to alpha/2=0..005.
Okay that's exactly what was wrong. Thank you so much for your help!
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
