I found a really weird function
  • Thread starter Thread starter Chuckstabler
    Function Weird
The discussion revolves around a user discovering a function related to the derivative of the square root of 4x^2 + 4, which resembles a normal distribution. The derivative simplifies to (4/(sqrt(4x^2+4)) - (16x^2/sqrt(4x^2+4)^3/2). Another participant explains that the function can be simplified to (x^2+1)^{-\frac{3}{2}} and notes that while it looks similar to a normal distribution on a linear plot, its tail behavior differs significantly. They also mention that the function's second derivative relates closely to a normal probability density function, providing insight into the observed similarities. The conversation highlights the mathematical properties that contribute to the function's appearance.
Chuckstabler
Hey all, so I don't even know how I managed to find this, So I'll walk you all through how I've spent my last couple hours.
I've been studying intro calculus, and I recently came across the chain rule. I was screwing around with finding the derivative of various functions like the square-root of 4x^2 + 4. I then took the derivative of square-root 4x^2 + 4 (I think that's the function I took, I screwed up somewhere, but oh well, it doesn't change the function that I found), and found it's derivative using the quotient rule, and after simplifying I was left with
You can find it on at this link: (It's a graphing calculator website), https://www.desmos.com/calculator/l68uv67zay
It looks remarkably similar to a normal distribution, and seems to exhibit some properties of a normal distribution, is it doing this for any particular reason?
Mathematics news on Phys.org
Why don't you reduce it to a common denominator and also factor out √4 from within the radical? What are you left with then?
Chet
Likes berkeman
Give me a bit, i'll work on it. Thanks for your comment :D
Your function can be simplified to$$(x^2+1)^{-\frac{3}{2}}$$
Functions like this don't look completely different from a normal distribution on a linear plot, but they have a completely different shape in the tails.
Likes suremarc
Your function has second derivative ##f''(x)=\frac{-3x}{(x^2+1)^{5/2}}##, which is approximately equal to ##-3xf(x)## when ##x## is small.
The function ##g(x)=e^{-\frac{3x^2}{2}}## has derivative ##-3xg(x)##, and furthermore ##f'(0)=g(0)=1##; so ##g## can be said to approximate ##f'## near ##0##. Coincidentally ##g## describes a normal PDF, so that explains why your function looks like a normal distribution. I would link a graph comparing the two (they are very close!) but I happen to be posting from my phone presently.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 28 ·
