I got a general question(not a math problem)
  • Thread starter Thread starter xlaserx7
    General
The discussion revolves around the relationship between the magnitudes of forces exerted and the lever arm distance in the context of torque. Participants are exploring the principles of mechanics related to levers and torque.
  • Participants are questioning the nature of the relationship between force and lever arm distance, with some suggesting a direct relationship through torque, while others dispute this notion. There is a focus on the conditions under which forces are applied, particularly regarding their direction relative to the lever.
The discussion is active, with participants presenting differing views on the relationship between force and lever arm distance. Some guidance has been offered regarding the application of force and its independence from the lever length, but no consensus has been reached.
Participants are navigating assumptions about the conditions necessary for torque, including the orientation of the applied force. There is an indication of varying interpretations of the fundamental principles involved.
xlaserx7
1. Homework Statement
what is the relationship between the magnitudes of the forces exerted and the lever arm distance over which the force were exerted?
2. Homework Equations
3. The Attempt at a Solution
the force and distance are directly related because T (torque) = F times (lever arm)
There is no relationship.
what?? why1? is it because the force has to be perpendicular to the center of rotation?
No.
It is because if you have a lever of a certain length, you can apply whatever force upon it. A tiny force or a huge force, your choice.
ahhh ok thanks
13K
