What Is the Radius of a Circle Tangent to the X-Axis?
  • Thread starter Thread starter Loppyfoot
    Circles
A circle with center at (-3, 4) is tangent to the x-axis, indicating that it touches the x-axis at exactly one point. The radius of this circle is determined by the vertical distance from the center to the x-axis. Since the y-coordinate of the center is 4, the radius is definitively 4 units. This conclusion is based on the geometric principle that a radius drawn to a tangent line is perpendicular to that line.
  • Understanding of basic geometry concepts, specifically circles and tangents.
  • Familiarity with the Cartesian coordinate system.
  • Knowledge of the definition of radius in relation to a circle.
  • Ability to visualize geometric relationships in two dimensions.
  • Study the properties of tangents and circles in geometry.
  • Explore the concept of distance between points in the Cartesian plane.
  • Learn about the relationship between radius and tangent lines in circles.
  • Practice solving problems involving circles and their tangents.
Students learning geometry, educators teaching circle properties, and anyone interested in understanding the relationship between circles and tangent lines.
Loppyfoot
Here it is:
A circle with center (–3,4) is tangent to the x-axis in the standard (x,y) coordinate plane. What is the radius of this circle?
I have no idea where to start. I know there is some rule about tangency and circles, but I am unsure. Thanks!
If it's tangent to the x-axis, then it touches the x-axis at precisely one point. Try drawing a circle and you should be able to figure out which point it touches the x-axis at
You really don't even need to draw a circle; you should be able to intuit the answer. If the mp is (-3,4) and it only touches 1 point on the x-axis, what is the radius. Isnt the (sort of in this case) definition of radius a ray as a line starting from a (mid)point and going infinitiely in one direction, in this case until it touches the axis? Then how far is that?
A radius is always perpendicular to a tangent line. Here, the x-axis is a tangent line. Therefore, a radius must be perpendicular to the x-axis. If the center is at (-3, 4), what is the other end of that radius? How long is it?
  • · Replies 18 ·
