I now have an HD DVD player - some basic questions
- Thread starter GCT
- Start date
10 replies · 4K views · last reply
Discussion
Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,594
Do you mean a player that plays HD DVDs (the format that lost to Blu-Ray), or a player that upconverts ordinary DVDs to HD resolution?
Versus a component-video connection (red/green/blue jacks), the resolution is the same, but there may be differences in crispness, brightness or color. The results vary depending on which particular player and which TV you're connecting. Sometimes HDMI is significantly better. Sometimes the differences are very small. Try both for a while and see which one gives better results on your system.
A composite-video connection (yellow jack) or S-video (round multi-pin jack) can pass only SD (480i), so either HDMI or component video will produce significantly better results on a HDTV.
I've never heard of that happening.
If you haven't done so, learn how to adjust your TV's picture controls (brightness, color, etc.) to optimize the picture. Most TV's come "out of the box" set to what many people call "torch mode" which is too bright, with oversaturated colors, etc. There are calibration DVDs that can help with this, or you can do it by eye with a lot of patience while watching movies or TV shows that have natural lighting and color. (Many movies and TV shows use unnatural lighting and color effects for artistic reasons.) If the brightness or color is too high, it can make the picture appear less sharp because of "bleeding" effects at edges of objects.
GCT said:1) Would the HDMI connection increase the resolution?
2) Does the DVD player perform worse as it ages with respect to the HD capabilities?
3) Are there any other features that I should know about to optimize the HD?
peter0302
- 876
- 3
Most likely yes. Some players and discs will not permit high definition output from the component cables. This is due to the (paranoid, IMO) belief that people would use $10,000 professional-grade hardware to tap into the component signal, re-digitize it, and pirate the film.GCT said:1) Would the HDMI connection increase the resolution?
So usually you have to use HDMI (or DVI if your player supports it) with HDCP to ensure you are always getting HD 100% of the time. Otherwise it might "down-rez" and you won't even know it.
Useless side note: I tried to convince the DOJ to launch an anti-trust action against the MPAA over this because people with older HDTVs (which didn't have HDCP) can get screwed because of this, and back in 2001 when they were talking about this it was a big deal. They weren't interested, and now almost all TVs have HDMI so it's not an issue.
No more so than any other piece of electronic equipment. It's suceptible to wear and tear like anything else.2) Does the DVD player perform worse as it ages with respect to the HD capabilities?
Make sure your player is actually set to the same resolution as your TV - 720p, 1080i, or 1080p. Sometimes players will default to 480i or 480p output without telling you.
Homework Helper
- 7,906
- 15
High-bandwidth Digital Content Protection - it encrypts the digital signal between the dvd player/computer and the TV.GCT said:Btw what's an HDCP?
It closes the analogue hole - the idea that however well they restrict showing the movie they think that someone would connect a digital scope to the cable and capture GB of data to copy a movie.
Homework Helper
- 7,906
- 15
No the software built into the player and the TV the data works with any HDMI cable.GCT said:Thanks. So would I need to buy a particular HDMI cable or is it universal?
It isn't a feature of standalone DVD players but is in Windows Vista and Blu-Ray - in which case your TV needs to support it.
Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,594
peter0302 said:Most likely yes. Some players and discs will not permit high definition output from the component cables.
For standard DVD players, this is true. Few if any standard DVD players upconvert via the component-video output, only via HDMI. With HD DVD players, the situation is different. They do deliver HD output from HD DVDs via both component-video and HDMI. However, they refuse to upconvert standard DVDs via component-video, just like standard DVD players!
I've used my HD DVD player with a component-video connection for a little while, just to see that it works that way. I normally have it connected via HDMI.
By the way, the "quality" of the HDMI cable shouldn't matter unless you need 25 feet / 8 m or more. And unless you're in a hurry, don't pay the astronomical prices that most bricks-n-mortar stores charge for HDMI cables (or any cables, for that matter). Use an online dealer that has good prices. You can get good cables up to 10 ft (3 m) or so for less than $10.
Mentor
- 23,906
- 11,368
The data on digital media and the devices that process them do not progressively degrade with time as the media and devices physically degrade.GCT said:2) Does the DVD player perform worse as it ages with respect to the HD capabilities?
peter0302
- 876
- 3
Whether it down-rezes component is up to the disc manufacturer. And often times you might not even know it's happening. But trust me, they can do it, and if a cheap HD analog-digital converter ever was devised, they'll start.jtbell said:For standard DVD players, this is true. Few if any standard DVD players upconvert via the component-video output, only via HDMI. With HD DVD players, the situation is different. They do deliver HD output from HD DVDs via both component-video and HDMI. However, they refuse to upconvert standard DVDs via component-video, just like standard DVD players!
- GCT
- · Replies 31 ·
- Computing and Technology
- Replies
- 31
