I think I get it now. Thanks for your help. You're welcome, happy to help!
The problem involves an object moving along a straight line with its position defined by the equation x = 4t^2 - t^3, where t represents time. Participants are tasked with finding the times at which the velocity and acceleration are zero, as well as calculating the average velocity over the first three seconds.
  • The original poster attempts to find specific times for zero velocity and acceleration, providing numerical answers for each. Other participants question the correctness of these answers and suggest that the method of solving should be shared for better understanding.
  • One participant differentiates the position function to find velocity and acceleration, raising questions about which zero velocity solution to consider. They also mention using the mean value theorem for calculating average velocity.
Some participants have provided feedback on the original poster's attempts, indicating that there may be multiple valid solutions for the velocity question. Guidance has been offered regarding the differentiation process and the calculation of average velocity, with acknowledgment that both zero and non-zero solutions for velocity are relevant.
Participants are encouraged to explain their reasoning and methods rather than simply providing numerical results. There is an emphasis on understanding the problem setup and the implications of the results obtained.
monkfishkev
An object starts from position X = 0 and moves along a straight line with its position given by x = 4t^2 - t^3 where t is the time taken to reach position x.
Find:
i) The time at which the velocity is zero
ii) The time at which the acceleration is zero
iii) The average velocity over the first three seconds.
2. The attempt at a solution
Please can somebody let me know if these answers are correct
i) 0.53s
ii) 0.27s
iii) -37s
Thanks
It's good if you try to sketch the graph of the function where you can evaluate you answers.
Hi monkfishkev
1) no, this is wrong, and the velocity is 0 more than once, it is 0 at 0 how are you solving this ?
2) wrong too, but you should write how you solved it instead of giving the numerical result so that we know if your method is wrong or if you just messed the numerical result (I suspect the former)
3) wrong too
Please explain how you understood the problem and how you solved it, the numerical result is much less important than showing how you get it
Cheers...
OK I've tried it a second time and come out with a different answer.
I differentiate x = 4t^2 - t^3 to become v = 8t - 3t^2
Making v = 0 I get either v = 2.6 or v = 0. How do I know which one to use.
I then differentiate further to solve for acceleration. a = 8 - 6t
when making a = 0 I get 1.3 seconds
Am I now on the right track?
Well I think the more -interesting- time would be the t=2.66 since the object was at origin and not moving at t = 0
for 3 you can just use mean value theorem for integrals right?
average f(x) from a to b = integral from a to b f(x)dx/b-a
Yes you are on the right track
for (1), as madah12 says, the case where t is non 0 is 'more interesting' so to speak. I would just formulate my answer stating that there are two good answers and give both instead of picking one. (if for some reason you absolutely must pick one, than the non zero one looks better yes)
(2) is ok too
for (3) you don't need anything fancy: you have the position at t=0, the position at t=3, the average speed is the distance by the time, so
[(position at 3) - (position at 0)]/3
position at 3 is 0, so your average speed is simply x(3)/3
Cheers...
  • · Replies 20 ·
