I thought conversions were simple
  • Thread starter Thread starter indepth
indepth
I thought conversions were simple, but this one is giving me some trouble. If anyone could help out, it would be greatly appreciated. Thanks in advance.
http://img225.imageshack.us/img225/6229/pjhyscb0.png
If there are 50 water drops of radius 10 um, what total volume is that?
im confused to find volume with only radius..:(
What's the volume of a sphere? (The radius is the only thing you need to know)
4.18879x10^-10 in meters
It's r^3, I think you may have done r^2. The units would be m^3 since it's volume, right?
V = \frac{4 \pi r^3}{3}
sorry, yeah ^3 i did squared. so.. 4.18879x10^-15
OK, so what's the volume of a cylinder of height 2.9 km and radius 1.4 km?
The way to approach this problem is to find out how many cubic centimeters there are in the whole cloud. Once you have that, you can figure out how much water there is in the entire cloud because you now know how much there is in one cubic centimeter.
Remember to write down your units. That's the whole point of this problem and you will make mistakes if you lose track of them.
So this should be in m^3.
Don't forget to multiply this by 50 to get the total volume of the 50 drops in the cubic centimeter of cloud.
in the cylinder, volume is 1.7856x10^10 m^3, right?
Yes, that's right.
after x by 50 the answer is 2.0949x10^-15. what do i do with the cylinder now?
So if there is 2.09x10^-15 m^3 of water for every cm^3 of cloud, how much water is there is 1 m^3 of cloud? (Just convert cm^3 to m^3)
Then, you can find out how much water is in the entire cloud by multiplying by the entire volume of the cloud you just found.
2.09x10^-12 per m^3. so now this times 1.7856x10^10 m^3?
1 m^3 = 100^3 cm^3. You must cube the 100.
So it should look like \frac{2.09x10^-15 m^3 water}{1 cm^3 cloud} * \frac{100^3 cm^3}{1 m^3}
Does that make sense?
yeah that looks good, i forgot about the cubing of the 100. and now same for the 500 correct? but also. that's not the final is it
Yes. What answer did you get?
2.09x10^-9 is what i got for the 50. now i will do it for the 500. any idea for part b and or c?
Don't forget to multiply by the entire volume of the cloud.
For (b) How many m^3 in a Liter?
For (c), what's density?
Give these a try and see what you can do.
3.7319x10^1 correct for 50?
B) .00 m^3
c) p= m/v
indepth said:
2.09x10^-9 i thought that was the asnwer after multiplying the vol of cloud.
No, the 2.09x10^-9 m^3 is the volume of water per m^3 of cloud. To find the total volume of water you must multiply by the total volume of the cloud.
B) .00 m^3
:confused:
c) p= m/v
Yes. So how might you use that to figure out the mass of water in the cloud?
OK, that looks better (watch your sig figs). Don't forget to state your units! It's a good habit to get into.
but is correct answer right? only 1 try on this homework problem :(.
.001 i meant to say sorry.
use mass of cloud divided by the volume we just found?
A) is correct thanks
B) .001 m^ = 1 L?
C) just use density formula?
indepth said:
B) .001 m^ = 1 L?
Yes. (m^3)
Yes, you know the volume now and you were given the density.
B) so i have .001 m^3. divide the #'s from a by this #?
C) i tried 1000/(answer from a) and it is not correct :(
Yes.
But mass = density * volume. You have to arrange the equation for mass.
If you check your units to see if they come out right you can catch these kinds of errors! :wink:
Thanks a lot, i got all parts right. Yeah i get confused a lot with my units, I am sure that's what messes me up the most. If you still have time i have one last problem.
http://img225.imageshack.us/img225/1765/pjhys2po4.png
Actually i figured it out. Thanks for your help, i am sure i will be in this forum board through the semester so i look forward to seeing you around. :) thanks
Start with the density equation again. Can you find the volume of 44.21 g of gold? How do you think you might find the area of the leaf using that information?
For (b), if you know the volume the gold fiber needs to be, what length will give you that?
Be careful with your units and remember to convert them when necessary.
  • · Replies 16 ·
  • · Replies 64 ·
