Ideal Gases equilibrium question
The discussion revolves around a problem involving two containers of gas at different pressures and temperatures, connected by a valve. The goal is to determine the final pressure after the valve is opened and gas flows until equilibrium is reached. Participants emphasize using the ideal gas law (PV=nRT) and the relationship between initial and final states of the gas in both containers. The challenge lies in calculating the number of moles before and after opening the valve, considering the fixed volumes and maintained temperatures. The conversation highlights the need for a clear step-by-step approach to solve for the final pressure while accounting for the differences in temperature and pressure between the two containers.
Sky.Anthony
Containers A and B in the figure hold the same gas. The volume of B is four times the volume of A. The two containers are connected by a thin tube (negligible volume) and a valve that is closed. The gas in A is at 300 K and pressure of 1.0*105Pa. The gas in B is at 400 K and pressure of 5.0*105Pa. Heaters will maintain the temperatures of A and B even after the valve is opened.
After the valve is opened, gas will flow one way or the other until A and B have equal pressure. What is this final pressure?
PV=nRT or PV=NkBT
P1V1/T1 = P2V2/T2
I've been messing around with this question for awhile and I'm getting nowhere. My initial thought was to use P1V1/T1 = P2V2/T2 but then I realized that all of the variables are given. Since the volume and temperature of each container is fixed, in order for pressure to change, there must be a change in number of gas molecules in each container... but this is where I'm stuck. I'm not sure how to integrate and establish an equation with number of particles per container where PA=PB while taking into account their fixed volumes and temperatures.
Opening the valve, gas will flow from B to A till the pressure is the same in both containers. Meanwhile the temperature of both containers is kept at the same level.
You have to collect the initial and final data for both containers and apply the the ideal gas law: PV=nRT, to get the initial and final number of moles (n) in both containers.
Container A:
initial state
Vi(A):V
Ti(A)=300 K
Pi(A)=1*10^5 Pa
ni(A)=1*10^5*V/(R*300)
final state
Vf(A)=V
Tf(A)=300 K
Pf (A)=P
nf(A)=PV/(R*300)
Do the same for the other container: express ni(B) and nf(B). The gas can not escape so ni(A)+ni(B)=nf(A)+nf(B). Use this equation to get the final pressure.
ehild
Likes BrainMan
Sorry to drag up an old thread, but I have the same basic problem with different data. is there anyone who can show me a step by step work through of this problem? the previous reply just isn't helping. It's an online assignment and I have already used up all my submissions, and just want to know how to do this problem.
Edit:
I've Determined the moles of gas in each container prior to the valve opening, but that's as far as I can get. Determining the moles of gas in each container after opening the valve is completely eluding me. The change in pressure and temperature from container A to B is really throwing me for a loop.
The work I've attempted is setting [P(a)V(a)/n(a)]+[P(b)V(b)/n(b)]=P(f)V(f)/n(f)
This never really looked right, but it was the closes I ever got to the right answer. I know the temperature difference must have something to do with it, but I am unsure of how to account for that.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
