What is the behavior of ideal voltage/current sources in small signal analysis?
  • Thread starter Thread starter jinyong
    Sources
The discussion clarifies the behavior of ideal voltage and current sources in small signal analysis. An ideal voltage source behaves as a short circuit with an impedance (Z) of 0, as the output voltage remains constant regardless of the output current. Conversely, an ideal current source acts as an open circuit with an infinite impedance, as the output current remains unchanged over varying output voltages. This behavior is mathematically represented by the equations Z = dv/di for both sources, leading to definitive conclusions about their characteristics in circuit analysis.
  • Understanding of small signal analysis concepts
  • Familiarity with ideal voltage and current sources
  • Knowledge of impedance calculations
  • Basic proficiency in LaTeX for mathematical expressions
  • Study the mathematical foundations of small signal analysis
  • Learn about the implications of impedance in circuit design
  • Explore the characteristics of non-ideal voltage and current sources
  • Practice using LaTeX for mathematical notation in technical documentation
Electrical engineers, circuit designers, and students studying small signal analysis will benefit from this discussion, particularly those interested in the theoretical underpinnings of circuit behavior.
jinyong
Can someone please explain why ideal voltage/current sources are short circuit for voltage source and open circuit for open circuit in small signal analysis? Any mathematical proof to this?
I would think of it in terms of Z = \frac{dv}{di} (although there may be other ways).
For a good voltage source, the output voltage is very stiff (doesn't change much) as the output current changes, so
Z = \frac{dv}{di} = \frac{0}{di} = 0
But for a good current source, you get very little change in the output current over a wide range of output voltages, so
Z = \frac{dv}{di} = \frac{dv}{0} = infinity
EDIT -- okay, I give up. How do you make the little infinity symbol in LaTex? "\inf" didn't work.
Berkman is correct.
Voltage source can provide infinite amount of current. And a current source can provide an infinite amount of voltage.
Z = V/I
infty
\infty
what said:
infty
\infty
Thanks what! :biggrin:
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
