Identifying series and parallel connections
92 replies · 10K views · last reply
gracy
In the arrangement shown,find the equivalent capacitance between A and B.
Circuit diagram with terminals A and B: a 15 microF capacitor in series with a parallel pair of 10 microF (upper branch) and 20 microF (lower branch) capacitors between the junction and B.
Capacitance in parallel
##C##=##C_1##+##C_2##
Supplied solution says
As,we can clearly see that ,capacitors 10μF and 20μF are connected between same points ##C## and ##B##(Parallel combination)
Two circuit diagrams of capacitors between terminals A and B. Diagram (a): 15 microF in series from A to node C, then a 10 micro F capacitor on a top wire and a 20 micro F capacitor between C and B, in parallel. Diagram (b): 15microF and 30micro F capacitors in series between A and B with node C between them.
They can be replaced by a single capacitor of capacitance given by
##C##=10μF+20μF=30μF
Thus circuit can be shown by (b).
Now ,the capacitors 15μF and 30μF are arranged in a row(sweries combination)
the equivalent capacitance is given by C such that
##\frac{1}{C}##=##\frac{1}{15}##+##\frac{1}{30}##=##10##μF
What I did not understand is
Why can't I replace them as fllows
Circuit diagram with terminals A and B; a 15 micro F capacitor lies between A and node C, and a 30 micro F capacitor runs in a separate branch from C to B.
Are you asking if there is a difference between these two?
Two circuit diagrams between points A and B: top, a straight line with a 15 micro F capacitor and a 30 micro F capacitor in series, with point C between them; bottom, the same two capacitors drawn at different positions with wires routed around, C at the junction.
Electrically, no: There is no difference. You can arrange circuit components in any way you wish on paper, draw wires or components at angles, make wires long or short, have wires wander all over the page, etc., and it will make no difference to the circuit. What matters is the topology of the network (what connects to what).
Can you please provide me easy tip for identifying which capacitors are in parallel connection and which are not?I can identify in simple cases but when it is complicated ,I can't.
Parallel components share two nodes for their connections. Series components have one node that they share exclusively (no other connections at that junction).
A simple visual aid for finding parallel components is to color each node a different color (that includes all the wiring that makes up a given node). Components that are in parallel will connect to the same two color pairs. An example from a recent thread involving simplifying a resistor network is demonstrative:
Hand-drawn resistor network with wires colored blue, red, yellow and green, with three batteries along the bottom and a current arrow labeled I at lower right.
All the resistors that connect to the same color pairs are in parallel. Note that all the horizontally drawn resistors have the color pair (Blue, Red), so they are all in parallel despite how complex the network appears.
What is exact definition of node in context of circuits.
You should check your course text or notes for an official definition.
But in simple terms, a circuit node is a conducting "island" in a circuit that is all at the same potential with respect to some fixed reference. Typically it is a conductive path (wire) that two or more components connect to.
gneill said:
Typically is a conductive path (wire) that two or more components connect to.
Here component can be capacitor,resistance ,keys ,switch ,bulb etc?
Resistors, capacitors, inductors, diodes,...: yes. Things like switches and keys: no.
Switches and keys can serve to change the domain of a node by extending or curtailing the conductor-connected region, but they are not electronic components in the intended sense of the word. They physically change the circuit topology when they are operated.
A (light) bulb is just a fancy name for a special purpose resistor :smile:
What about batteries?
Are 1,2,3,4,5,6,7,8 nodes?If yes ,are 1,2,3 three different (separate)nodes?are 5,6,7,8 four different (separate)nodes?
Hand-drawn circuit diagram with numbered circled points 1 to 8, resistors in blue and red wire branches, two batteries along the bottom, a current arrow labelled I, and a green and yellow wire at the lower left.
gracy said:
Are 1,2,3,4,5,6,7,8 these nodes?If yes ,are 1,2,3 three different (separate)nodes?are 5,6,7,8 three different (separate)nodes?
In case gneill is busy.
Everything in blue is part of the same node. It's all made of ideal conductor.
Everything in red is part of the same node. - a node different from the blue node.
gracy said:
Are (1) and 2 two different (separate)nodes?
No. They are both on the same wire path. Everything with the same color belongs to one node.edit: Ha! SammyS snuck in there while I was otherwise occupied :smile:
No.
In post #11:
The entire blue wire constitutes a single node. Points 1, 2, and 3 are all located on this same node.
Points 5, 6, 7, and 8 are located on the red node.
Point 4 is on the yellow node.
Are component 1,2,3 underlined in blue in series? I think yes because they share a common node as highlighted by pink circle.
Hand-drawn circuit schematic with three resistors labelled 1, 2 and 3 in a horizontal branch, each underlined in blue, with an ammeter marked A in a vertical wire, nodes numbered 1 to 8, and a battery chain with current arrow I.
Yes: batteries and other voltage sources, also current sources, are components.
No they are not in series. A pair of components in series share a single node exclusively (all alone, with nothing else connected to that node: Just one wire each from two components). The red and blue nodes have a lot of component connections, not two. That section of wire "A" alone that you've identified has four components connected to it!
Besides, those components were identified as being in parallel earlier in the thread. The only case where components can be both in series and in parallel is when there are only two components in the circuit. Then their connections will agree with both definitions:
Circuit schematic of a capacitor labelled C and a resistor labelled R connected in parallel across the same two nodes, forming a closed loop.
Which four?
gracy said:
Which four?
Sorry, I think that's a frivolous question. Surely you can see which resistors have wires touching wire segment A? (Include its bottom end!).
But this implies three components can never be in series.
Did you mean if thee are two components in series (that's why you used"pair of component)then othing else connected to that node: Just one wire each from two components)
and if component are in series then only three components should be connected to that node but A has 4 components connected to it,hence it is wrong!Right?
Are component 1,2,3 ,4 underlined in blue in series? I think yes because they share a common node "A"as highlighted by pink circle.
Hand-drawn circuit diagram with numbered nodes 1 to 8 and resistors labelled 1 to 4, wires in red, blue and green, and batteries with current arrow I; components 1 to 4 are underlined in blue.
No it does not. For any number of components in series the connections between the components are exclusive -- only two components connect at any node along the path. There is a single path for current to follow through the string of components. No current can leave the path, and no current can join.
gracy said:
Did you mean if thee are two components in series (that's why you used"pair of component)then othing else connected to that node: Just one wire each from two components)...
Yes.
...and if component are in series then only three components should be connected to that node but A has 4 components connected to it,hence it is wrong!Right?
No, only two components can be connected to any node along a series-connected path. Wire segment "A" has four components connected to it, so none of the components connected there are in series with any of the other components connected there. And, segment "A" is only a small portion of the overall node that is colored in blue. The entire connected path colored in blue is one node, and there are even more components connected to it.
No! There are more than two connections at that node. It is not exclusively shared by exactly two components.
Not even 1 & 2?
gracy said:
Not even 1 & 2?
No. Their connection is not exclusive.
Gracy, there is only one series connection in that entire circuit. That is the resistor and battery in the bottom left corner. They share an exclusive connection.
Extremely Sorry,if I am irritating you.
But I am unable t understand if this is the case
how is it possible to have more than 2 connections in series?
