Identifying series and parallel connections
92 replies · 10K views · last reply
gracy said:
Extremely Sorry,if I am irritating you.
But I am unable t understand if this is the case
how is it possible to have more than 2 connections in series?
Circuit schematic of a series connection: a resistor, a capacitor and a second resistor in a line, with two nodes marked where the components meet, and the caption 'Series: Each node along the path is exclusively shared by only two components'.
Circuit schematic of a series connection: two resistors and a capacitor in a single line, with the two nodes between the components labelled nodes, and the caption Series: Each node along the path is exclusively shared by only two components.
Here capacitor,and the two resistance are in series,Right?
Hand-drawn circuit schematic with six resistors and three cells, with the wires coloured blue, red, green and yellow to mark connected nodes; a current arrow labelled I is at the lower right.
gneill said:
Gracy, there is only one series connection in that entire circuit. That is the resistor and battery in the bottom left corner. They share an exclusive connection.
You mean the two connections of yellow node?
If yes that means I understood series connection.
gracy said:
Circuit schematic of a series connection: a resistor, a capacitor and a second resistor in a line, with the text "Series: Each node along the path is exclusively shared by only two components" and arrows labelled "nodes" pointing to the junctions between components.
Right.
Yes.
In (1) all 1,2,3 are in series but in (2) only 2 and 3 are in series but 1 and 2 and 1 and 3 are not in series,right?
I don't know what you are referring to. What are (1) and (2) ?
Two circuit diagrams with a series-connection note: circuit 1 has resistor 1, capacitor 2 and resistor 3 in a single loop; circuit 2 adds a capacitor branch on the bottom wire, with nodes marked between components.
Sorry!I clicked on post reply reply but was intended to click on upload!
Here no components are in series,Right?
Circuit schematic with two resistors and two capacitors in a closed loop, with blue and red highlighted wires marking paths; labelled 'Series: Each node along the path is exclusively shared by only two components' and 'nodes' with arrows.
Sorry if my resistor looks odd!:smile:
In (1) all three components are in series, yes.
In (2) capacitor 2 and resistor 3 are in series, yes, but they are also in series with the capacitor that you've placed at the bottom. Resistor 1 is not in series with anything, in fact it is "shorted out" by the wiring that connects both of its ends.
Now what is shorted out!Are not you afraid of opening a brand new topic:smile:
On a serious note I want to ask one thing
How do you decide to bring new wire in I mean switching to yellow from blue,I faced this problem while drawing circuits in post #38 and #40.
Two resistors are in series, but they are shorted out (bypassed) by the red path joining their outer ends.
Gracy, it should not be necessary to enumerate every possible permutation of connections in order to understand the concept. If there is a single, undivided path for current to follow through a set of components then they are in series. If current has optional paths through other components anywhere along the way then they are not in series.
But I can see only one
that is
Circuit schematic with the caption 'Series: Each node along the path is exclusively shared by only two components', showing two resistors and two capacitors in a loop, with nodes marked and points a and b labelled.
gracy said:
Now what is shorted out!Are not you afraid of opening of a brand new topic:smile:
"shorted out" means that there is a low (usually zero) resistance path bypassing a circuit or portion of a circuit. It's a "short path" for the current to follow rather than flow though the circuit.
How do you decide to bring new wire in I mean switching to yellow after blue,I faced this problem while drawing circuits in post #38 and #40.
I've explained that a node is isolated, contiguous wiring. If you follow a continuous wire path between two points, then they belong to the same node.
Each colored "island" in the diagram is contiguous wiring.
Now I think I have got what is series connection .And the credit goes to definitely you!
I want to understand about parallel connection now!
gneill said:
No, only two components can be connected to any node along a series-connected path.
What happens in parallel connection?
Things that are in parallel have the same potential difference because they all connect to the same pair of nodes. Is that what you mean?
Is not this applicable for parallel connections?
No, any number of components can be in parallel and share the same pair of nodes (only two nodes are required for any number of parallel components).
Any number of components can be in series, too, but every pair of them along the series connected path requires an isolated node for their connection.
Here node implies highlighted pink portion "A "or complete blue portion(if we refer image in post #17)
As an example, yes. The blue wire segment is one node. The red wire segment is another node. The highlighted pink portion is just a portion of the blue node, it is not a separate node.
Components that share both of those nodes (red, blue) for their connections are in parallel.
By isolated node (that you used in explanation of series connection)means
orange portion "a" here
it appears like a single line
Hand-drawn circuit diagram with resistors, batteries and a current arrow I; orange portion a, red portion b and blue portion c are labelled in the key on the right.
Resistors 1,2,3,4, and 5 are in parallel connection.
Hand-drawn circuit diagram with five resistors labelled 1 to 5, three batteries, and a current arrow labelled I; wires are coloured blue, red, green, yellow and black.
And there are no other components in parallel connection.
Right?
Sorry but it gives me confident to move further.As I am satisfied that till here my all concepts are clear and I should move forward.
Right?
Correct.
No, it is not isolated. It is a small portion of the larger whole (blue network) which has other connections.
Based on my observation of our diagram
A node can not cross any component,right?
I mean it will be wrong if I will replace green wire with yellow wire because by doing thatyellow wire will crss the component(battery)
Hand-drawn circuit diagram with resistors and batteries in colored wires: blue, red, yellow and black, with an arrow labelled I showing current direction.
