If a with respect to b, which is the independent variable?
The discussion revolves around the interpretation of a T-v diagram, specifically regarding the independent and dependent variables represented in such diagrams. The original poster questions whether specific volume or temperature should be considered the independent variable when discussing their relationship.
  • Participants explore the definitions of independent and dependent variables in the context of T-v diagrams, with some suggesting that temperature is typically the independent variable. Others express confusion about the terminology and the conventional representation of variables on graphs.
There is an ongoing exploration of the conventions used in graphing relationships between variables. Some participants provide examples and seek clarification on the terminology, while others question the standard practices and express differing opinions on the representation of variables.
Participants note that the discussion is influenced by conventions in scientific diagrams and the potential for different interpretations based on context. There is also mention of the importance of clarity in communication regarding variable relationships.
Zheng_
My lecture note says that "T-v diagram shows change in specific volume of a substance with respect to temperature.". Is it correct?
If a(Specific Volume) "with respect" to b(Temperature), then b(Temperature) should be the independent variable. But T-v means that specific volume(v) is the independent variable right?
Here are a couple examples I found online:
Dropout voltage also varies with respect to temperature.
The sum of the two voltages remains constant with respect to temperature.
So yes, temperature is the independent variable.
I'm not sure what a T-v diagram is. Can you explain?
Something like this
Okay. Then if what he said is in reference to a chart like the one above, then it appears that he should have said, "temperature with respect to volume". You may want to ask him for clarification.
Ok. Thanks for the help!
One of the phrases that always bothered me was describing a chart using the term "vs". As an example, saying "voltage vs. current" describes a graph where voltage is the independent variable (x axis) and current is the dependent variable (y axis). It always seemed to me that chart should have been called "current vs. voltage" - that saying "vs." should be equivalent to saying "with respect to". But that's not how it's done.
So in your T-v chart example, one should say "volume vs. temperature. But to me that seems backward.
When talking about the gas equation PV=nKT you have three variables and can plot anyone against any other. Any of the three can be the independent variable so there are 6 possible graphs. I think it's only by convention that we normally stick to these three...
T-V Diagrams (Y axis = Temperature, X axis = Volume)
P-V Diagrams (Y axis = Pressure, X axis = Volume
Phase Diagrams (Y axis = Pressure, X axis = Temperature)
Regarding Ohms law... Most people know it as V=IR so you might expect the Y axis to be Voltage, but if you look up the definition you find..
https://en.wikipedia.org/wiki/Ohm's_law
Ohm's law states that the current through a conductor between two points is directly proportional to the voltage across the two points.
But if it is a T-v diagram, doesn't it means that v must be the independent variable(x-axis)?
Zheng_ said:
But if it is a T-v diagram, doesn't it means that v must be on the independent variable(x-axis)?
Reference https://www.physicsforums.com/threa...o-b-which-is-the-independent-variable.896384/
Also, the question I'm trying to ask is "if a with respect to b, which is the independent variable?
R
Also, if a with respect to b, which one is the independent variable?
T-V diagrams are usually drawn with T on the y-axis and V on the x axis, however if someone was to do an experiment where T was the independent variable they would probably still plot T on the y-axis because people are more familiar with seeing T-V diagrams that way around. It makes it easier to compare data with other experiments.
Normally b would be the independent variable.
