If basis change, how metric hcange?
This discussion focuses on the transformation of a metric tensor during a basis change in a two-dimensional vector space, specifically using the Minkowski metric Q=[-1,0;0,1]. The transformation is linear with a determinant of 1, and participants explore how to compute the new metric tensor coefficients after the transformation. It is established that if the transformation is a Lorentz transformation, the metric is preserved, and the norms of the vectors remain invariant. However, if the transformation is not Lorentz, the norm of a non-zero vector can become zero, as illustrated by a specific transformation yielding a new metric of [[0,-1],[-1,0]].
  • Understanding of linear transformations and their matrix representations.
  • Familiarity with metric tensors and their properties in vector spaces.
  • Knowledge of Lorentz transformations and their implications on metrics.
  • Basic proficiency in linear algebra concepts, including determinants and scalar products.
  • Study the properties of Lorentz transformations and their effects on metric tensors.
  • Learn how to compute the new metric tensor coefficients after a basis change.
  • Explore the implications of non-invertible transformations on vector norms.
  • Investigate the relationship between scalar products and metric tensors in different bases.
Students and professionals in physics and mathematics, particularly those focusing on linear algebra, general relativity, and the study of vector spaces and metrics.
LuisVela
I have a vector space (dim=2) with given basis (x1,x2), and a metric Q=[-1,0;0,1] (Minkowsky metric). Now i perform a transformation on the basis of the form y1=y1(x1,x2), and y2=y2(x1,x2)..the transformation is linear, and the determinat of its matrix is equal to 1.
Does the metric changes?...in that case, how can i find the coeficients of the metric tensor? (coeficients of the matrix)?
Hope i explained myself good enough.
I don't know if i need to specifie more about the transformation. i think to say that its linear, and detT=1 will suffice.
I tryed to go to the definition of the components of the metric tenzor...which will satisfy the equation: [Qij=(yi,yj), where the symbol (.,.) means scalar product.
But of course i don't know how tot ake the scalkar product...i mean..should i use the old metric?
Im really lost here..i don't know what to do...
Thx in advance
Let's look at it more generally, using linear algebra.
Suppose you have some linear transformation T which corresponds to a matrix A in some specific basis. Do you know how to construct a matrix C that changes basis, and how to use this to represent T in the new basis (i.e. write the matrix belonging to T with respect to the new basis, in terms of A and C)?
Hi. Yes i do.
Let be [e1,e2] and [f1,f2] basis and C a matrix such that [f1,f2]=C[e1,e2].
Let T be a lin. transf. (represented by the matrix A) of the basis [e1,e2].
...The transformation T (matrix A) expressed in the basis [f1,f2] is equal to C^(-1)*A*C
Go on...
Well, the metric tensor is just a 2 x 2 matrix.
So in principle, you can construct the change-of-basis and calculate the new metric.
Note that if the basis change is a Lorentz-transformation (i.e it only rotates and boosts the basis vectors) then the metric will be preserved.
Thank you very much. That will help me.
One more thing though. When you say that the metric is preserved, will that imply that the norm of the vectors will be invariant?
Is just that in my case, i found that the norm of the vectors which expand the new space (the new basis) is cero!...is that possible?
Yes, if the transformation is a Lorentz transformation then also the norm
||\vec a||^2 = \vec a \cdot \vec a = a^\mu a_\mu
of vectors will be preserved.
If it is not a Lorentz transformation, the norm of a non-zero vector can become zero. For example, consider a (non-invertible!) transformation where you collapse both basis vectors onto the light cone. Any vector will now be projected onto the light cone and have zero norm.
...(how did you write in latex?)
Thanks for the reply. It was of great help.
my transformation is the following:
<br /> u=\frac{1}{\sqrt(2)}(t-x)\\<br /> v=\frac{1}{\sqrt(2)}(t+x)<br />
in the coordinates (t,x) the metric is the minkowsky metric
<br /> \begin{array}{cc}-1&amp;0\\0&amp;1\end{array}<br />
I found that in the new coordinate system the metric is
<br /> \begin{array}{cc}0&amp;-1\\-1&amp;0\end{array}<br />
The basic vetors then (expresed in the new coordinates ) are e_{u}=(1,0) and e_{v}=(0,1)
Now, if you calculate the norm of e_{u} \ e_{u} it will be =0. My question now is: should i calculate their norm using their representation according to the old metric?..i.e.
<br /> e_{u}=\frac{1}{\sqrt(2)}(1.-1)
<br /> e_{v}=\frac{1}{\sqrt(2)}(1.1)
..in which case..its conserved..i.e. its equal to 1.
