If f is even then then left and right integrals are equal
  • Thread starter Thread starter Euklidian-Space
    even Integrals
The discussion revolves around the property of even functions in the context of definite integrals, specifically examining the equality of integrals over symmetric intervals. The original poster attempts to demonstrate that if \( f \) is an even function, then the integral from \(-a\) to \(0\) is equal to the integral from \(0\) to \(a\).
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the use of substitution to relate the two integrals, questioning how the limits of integration change with variable substitution. There is discussion about the implications of reversing integration limits and the role of dummy variables in integrals.
Participants are actively engaging with the problem, raising questions about the steps taken and clarifying concepts related to integration. Some guidance has been offered regarding the use of substitution and the treatment of dummy variables, but there is still uncertainty about the implications of these steps.
There is an ongoing debate about the handling of negative signs during substitution and the interpretation of dummy variables in integrals. Participants express confusion about how these concepts affect the equality being proven.
Euklidian-Space
If ##f## is an even function then $$\int_{-a}^{0} f = \int_{0}^{a} f$$
My attempt was trying to show the upper sum of both integrals were equal.
Take a partition of [-a,0] call it ##P_{1}##, and ##P_{2}## for [0.a].
if we can show that ##U(f,P_{1}) = U(f,P_{2})## I think that might do it. However, i am not sure how to get there
I think it would be helpful to know that f is even if f(x) = f(-x)
Just do a substitution, say, y=-x. Then the result follows.
is that a substitution on the limits or the variable?
Yes (to both). If you change the variable, the limits of integration change as well.
ok i keep getting a negative in there and I can't figure out how to get rid of it. here is my working
$$\int_{0}^{a} f(x) dx = \int_{0}^{a} f(-x) dx $$
let ##y = -x## ##\rightarrow## ##dy = -dx##. So we now have ##-\int_{0}^{-a} f(y) dy = \int_{-a}^{0} f(y) dy##
now if i sub -x back in for y I get a negative infront again since du = -dx. Any thoughts?
Yes. When you reverse the order of the integration limits, the sign of the integral changes.
IOW, ##\int_a^b f(x)dx = -\int_b^a f(x)dx##
Please do not start with what you need to prove.
Try to start from LHS and end with RHS.
He (or she) is not starting with what needs to be proved.
Let f be any odd function, then lim x -> -a (f(-a)-f(x))/(-a-x) = (-f(a) - f(x))/(-a-x) = (f(a) + f(x))/(a+x) = (f(a) - f(-x))/(a-(-x)) = lim y -> a (f(a) - f(y))-(a-y)this proves that f'(-a) = f'(a), now since your function is even, it must be a derivative of and odd function , Good luck ;)
Edit, y = -x , just for the fancy notation !
Yeah but isn't that not what we want. Maybe i am not seeing something but it seems we wouldn't want the negative out in front?
Try doing the substitution only on one side of the equation you started with.
lim y -> a (f(a) - f(y))-(a-y) this is meant to be lim y-> a (f(a)-f(y))/(a-y)
but i have been working on just one side. i do not see a point where i stop working on the side that I "started" with
Oh, I misunderstood what you wrote. You got
$$\int_0^a f(x)\,dx = \int_0^a f(-x)\,dx = -\int_0^{-a} f(y)\,dy = \int_{-a}^0 f(y)\,dy.$$ Do you see that you've shown what you setting out to prove?
But the variables are different no? When you sub -x back in for y wouldn't you get $$-\int_{-a}^{0} f(-x) dx?$$
Remember the variable of integration is a dummy variable.
I am sorry if I am being difficult vela, but I just don't understand why showing
$$\int_{0}^{a}f(x)dx = \int_{-a}^{0} f(y) dy$$
shows that
$$\int_{0}^{a}f(x)dx = \int_{-a}^{0} f(x) dx$$
if anything i think i have shown...
$$\int_{0}^{a} f(x) dx = -\int_{-a}^{0} f(x) dx$$
$$\int_{0}^{a}f(x)dx = \int{-a}^{0} f(y) dy$$
shows that
You may want to use the Edit feature to fix your typo !
No that's what i meant...
Since dy = -dx we get that negative out in front done we?
So ##\displaystyle \ \int{-a}^{0} f(y) dy\ ## is not a typo ??
What does it mean ?
What does it mean ?
oh sorry, didnt see that. it is fixed now.
shows that
Well it's like this:
##\displaystyle \ \int_{-a}^{0} f(y) dy\ ##
##\displaystyle \ =\int_{-a}^{0} f(t) dt\ ##
##\displaystyle \ =\int_{-a}^{0} f(u) du\ ##
It's even equal to ##\displaystyle \ \int_{-a}^{0} f(x) dx\ ##
That's what vela means by "it's a DUMMY variable."
Again I am sorry man i just don't understand. dy = -dx right? then how does ##\int_{-a}^{0} f(y) dy = \int_{-a}^{0} f(x) dx##? when dy = -dx? I do not see how using a "DUMMY variable" justifies dy = -dx to dy = dx
Again I'm sorry man i just don't understand. dy = -dx right? then how does ##\int_{-a}^{0} f(y) dy = \int_{-a}^{0} f(x) dx##? when dy = -dx? I do not see how using a "DUMMY variable" justifies dy = -dx to dy = dx
Look at a specific function.
Do the following integrals give different results?
##\displaystyle \ \int_{-2}^{0} (x^2+3) dx\ ##
##\displaystyle \ \int_{-2}^{0} (u^2+3) du\ ##
