If f(z) is 1-1, then f'(z) is not zero.
  • Thread starter Thread starter Bacle
    Zero
The discussion centers on the theorem stating that if a function \( f(z) \) is one-to-one (injective) in a region \( R \), then its derivative \( f'(z) \) cannot be zero in that region. Participants explore the implications of this theorem, particularly using a contradiction approach where they assume \( f'(z_0) = 0 \) for some \( z_0 \) in \( R \). They derive that \( f(z) \) can be expressed as \( f(z) = z^k g(z) \) for \( k > 1 \), leading to the conclusion that \( f(z) \) is not injective due to the existence of multiple pre-images. The discussion also touches on the necessity of proving the analyticity of the inverse function when \( f'(z) \) is zero.
  • Understanding of complex analysis, specifically the properties of holomorphic functions.
  • Familiarity with the concept of injective functions and their derivatives.
  • Knowledge of the inverse function theorem in complex analysis.
  • Experience with analytic functions and their representations, such as \( f(z) = z^k g(z) \).
  • Study the properties of holomorphic functions and their derivatives in complex analysis.
  • Learn about the inverse function theorem and its applications in complex analysis.
  • Investigate the implications of the argument principle in complex analysis.
  • Explore the concept of branch cuts and their role in defining multi-valued functions like \( g(z) = h(z)^k \).
Mathematicians, particularly those specializing in complex analysis, students studying advanced calculus, and anyone interested in the properties of analytic functions and their derivatives.
Bacle
Esteemed Analysts:
I am trying to rigorize the result that if f is 1-1 in a region R, then f'(z) is not zero in R.
This is what I have: Assume, by contradiction, that f'(zo)=0 for zo in R. Then
f can be expressed locally as :
f(z)=z^k.g(z)
for g(z) analytic and non-zero for some open ball B(zo,r)-{zo}
From this, we have to somehow use the fact that z^k is k-to-1, contradicting the
assumption that f is 1-1.
I don't know if we can use the fact that an open ball is simply-connected to
define a branch of log, from which we can define a branch of z^k, and then
conclude with the contradiction that f(z) is not 1-1.
Any suggestions for rigorizing?
Thanks.
One argument goes as follows:
WLOG z0=0 and f(0)=f'(0)=0. So f(z)=zkg(z) for some integer k>1, g analytic and nonzero in a n'hood of 0. So we can take a kth root of g, say g(z)=h(z)k. So f(z)=(zh(z))k. Now zh(z) is a nonconstant holomorphic function (if it's constant, it's zero, so f is 0 identically) and so it's an open map. So the image of any open n'hood of zero is open, and hence contains some open disc around 0. This must include points different by a factor \exp(2\pi i/k), from which f is not injective.
Likes WWGD
Thanks, henry_m:
Yes, that is along the lines I was thinking, but I did know how to justify the
existence of a holomorphic k-th root in a ball about 0; I was thinking of using
the fact that a ball is symply-connected, so that we can define a branch of log,
from which we can define a root, but there may be other ways of showing the
existence of a k-th root in B(zo,r)?
Are you worried about the step of finding h given g? You don't quite need to use the fact that a disc is simply connected, basically because we only need to be able to work in a tiny disc around z0.
In more detail:
Pick some disc around g(z0) not containing zero. It should be clear that we can define a branch on the logarithm in this disc. Then h(z)=exp(log(g(z))/k) defines h on the preimage of this disc, which contains z0.
Question: Consider f(z)=z^3. Then, isn't f(z) 1-1 and f'(0)=0?
Not in the complex plane. For instance, let \zeta = e^{2 \pi i/3}. Then \zeta is a primitive third root of unity, so
<br /> 1 = \zeta^3 = (\zeta^2)^3 = 1^3.<br />
So f is actually 3-to-1. You are correct for the real line, though, f(x) = x3 is one-to-one on the reals.
As for the original question:
If f is one-to-one on R, then it has an inverse f^{-1} \colon f(R) \to R. I think the derivative of the inverse is given by
<br /> (f^{-1})&#039;(w) = \frac{1}{f&#039;(z)}<br />
where f(z) = w. So f'(z) can't be 0 or (f-1)' will blow up at f(0).
Does this work? I might have forgotten a condition...
The problem with this argument is that you assume that the inverse is analytic, which must be proved.
The normal complex inverse function theorem assumes nonzero derivative, and proves existence of a continuous inverse, and then analyticity of the inverse and the formula for the inverse. You are trying to use the formula without the first assumption. To see what goes wrong if we try to use the formula here, the argument for the last part goes like this:
Let g be an inverse for f, and w, w' be in the domain of g and not equal. Let z=g(w), z'=g(w'). Then z and z' are not equal, and:
\frac{g(w)-g(w&#039;)}{w-w&#039;}=\frac{z-z&#039;}{f(z)-f(z&#039;)}
Now as w tends to w', z tends to z' (continuity of g needed) and so the RHS tends to 1/f'(z'), which proves what we wanted; g is differentiable with g'(w')=1/f'(z').
BUT if we haven't assumed that f' is nonzero, we have proved only that the limit, and hence the derivative of g, does not exist if f' vanishes somewhere. There is no contradiction since we haven't proved that the inverse is differentiable.
Spamiam:
The problem is that I don't know how to tell if 1/f'(z) is analytic or not.
My approach is this, assuming that if f is 1-1, then f'(z) is not 0:
The Jacobian matrix of an analytic function is an antisymmetric Jacobian,
with the entries the partials of U,V with respect to x,y respectively. Since
f'(z) is not zero, the determinant J(f):=U_x^2+U_y^2 is itself not zero, so J(f)
is invertible. You can then show that the form of the inverse J(f)^-1 is the same
as that of J(f), i.e., J(f)^-1 is also antisymmetric, and contains the partials
of f^-1(z) with respect to x,y, and these satisfy Cauchy Riemann, by the
symmetry of the inverse matrix.
Ah okay, I thought I was forgetting something. Thanks for the correction.
Actually, Spamiam, I think your statement is true if f(z) is real ( tho the names are changed
the innocent :) ):
If f(z)=U+iV is analytic, then:
Ux=Vy
Uy=-Vx
But , given 1/f'(z)= f'(z)^/f'(z).f'(z)^ (with ^ complex conjugation )
=U-iV/|f'(z)| , forces Ux=Vy=-Vy , so that Vy is constant; same for other component functions.
  • · Replies 32 ·
  • · Replies 24 ·
