If in Ring, evaluate (a+b)(c+d)
  • Thread starter Thread starter apalmer3
    Ring
8 replies · 4K views · last reply
apalmer3
If a,b,c,d [tex]\in[/tex] R, evaluate (a+b)(c+d). (R is a ring.
I think that it's simple foiling, but I'm not sure.
ac+ad+bc+bd
Why would you suspect this not to be true?
If you're in doubt re-check the definition of a ring.
I doubt it simply because I'm in a 4000 level Math course. It can't be this easy an answer.
Well, if there's no more information about a,b,c,d than I don't know what else you could do :smile:
Okay, so I'm going to guess that everyone agrees with me that this is right? It just seems too easy! Oh well, I'll accept it and move on. :-D
Treat (a+d) as one element and use the distributive property of rings. Then use it again. Make sure you keep the ordering if you're not dealing with a commutative ring.
Okay, that makes sense, PingPong! So, technically, the order is different.
(a+b)(c+d)
=> (a+b)c+(a+b)d
=> ac+bc+ad+bd
Right, but remember that in a ring, addition is commutative, so your order doesn't matter. What I said about ordering was meant to be applied to multiplication (unless you're dealing with a commutative ring). So what you had at the beginning was correct, but now you see why!
EDIT: Actually as a side note, commutativity of addition in a ring is an unneeded axiom, because it follows from the distributive property. If you treat (c+d) as one element, the distributivity property gives (a+b)(c+d)=a(c+d)+b(c+d)=ac+ad+bc+bd. This means that ac+bc+ad+bd (your method) is equivalent to ac+ad+bc+bd, or ad+bc=bc+ad. Thus addition is commutative.
