If space is not continuous, then is calculus wrong?
92 replies · 18K views · last reply
phinds said:
I'm an engineer. Zeno's paradox says you can't get from here to there. My experience says you CAN get from here to there. As an engineer, that pretty much ends it for me.
Then how do you refute/explain the paradox?
Simple: It's nonsense.
The non-technical part of me sees that philosophers worry about the silliest things. Next.
The engineer in me sees this simple answer as obviously true. I get from A to B all the time. Next.
The physicst in me sees that until we know better, space and time are continuous. Motion is not a bunch of discrete tasks. Next.
The mathematician in me sees that under the right conditions, a countably infinite number of finite numbers can sum to form a finite number. This is one of those conditions. Next.
Yep. Personally, I'm particularly attached to the engineer point of view but the others are just as good.
Just for my own understanding ... could you please point out the specific logical flaw in Zeno's paradox? Saying "it's nonsense" has a certain rhetorical finality; but it's lacking in the intellectual satisfaction department.
See all the other points in D_H's post. For me, his final point is the most persuasive. Zeno maintained that an infinite number of finite steps could not be finite. This was his mistake.
Hello, Steve,
There is actually slightly more to Zeno than can just be dismissed with a wave of a paw.
Not all infinite series have a finite total.
[tex]1 + 2 + 3 + 4 + 5 + 6... \to \infty[/tex]
However take "the arrow can never reach its target because before it can travel the whole distance it must travel half the distance. Before it can travel the remaining half it must travel half of that and so on."
Here the series does sum to a finite total
[tex]\frac{1}{2} + \frac{1}{4} + \frac{1}{8} + \frac{1}{{16}} + \frac{1}{{32}}... \to 1[/tex]
So we have to take care with infinite series.
jessjolt2 said:
Ok so mathematically you can divide any number by any other (nonzero) number and you can keep dividing that number however many times you want. Like dividing 1 by 2 and then by 2 again etc. And this is the basis of the famous paradox that mathematically, you can't really move from point a to b because first you need to get to the middle of a and b. and then to the middle of the middle. and then the middle of the middle of the middle, etc.
But what if space is not continuous, but quantized? Like what if there is a smallest possible length, and you cannot be in between that length, meaning you cannot physically divide that length by 2 to get to the middle (even though mathematically you could). Wouldnt that have some serious consequences on the physical application of calculus to the real world? (maybe not when working with large bodies, but definitely with small scales?) For example the intermediate value theorem wouldn't hold true...
Idk I am not calculus expert (only had calc I and II nd basic physics) but this thought occurred to me and has bothered me..
Not necessarily. One might still use a continuous model to accurately predict quantized measurements.
Studiot said:
Hello, Steve,
This is exactly my point. That is a mathematical solution, which of course I've known about for years. The question on the table today is, what is the physical solution?
We have no scientific evidence or even a good theory to support the idea that a convergent infinite series can be summed in the physical universe. Nobody has ever shown the physical existence of real numbers, infinite sets, arbitrarily small intervals, and all the rest of the set theoretic mechanism needed to develop the mathematical theory of convergent infinite series.
In fact my understanding is that a physical solution to Zeno's paradox does not yet exist. Of course one can always wave one's hands and say, "Well ... it's nonsense!" but that type of argument carries no weight on a physics forum.
In fact my understanding is that a physical solution to Zeno's paradox has not been proposed. Of course one can always wave one's hands and say, "Well ... it's nonsense!" but of course that type of argument carries no weight in science.
Zeno's argument, and his "paradox", was based on his (incorrect) belief that a infinite series cannot be summed to a finite number. Therefore, refutation of this fact is a refutation of Zeno's entire paradox, with all its physical implications. In fact, there is no paradox at all, rather it should be called "Zeno's mistake".
However, if you need a physical demonstration take a pad and a pencil. Draw two points a finite distance apart. Draw a line connecting the two points.
Hello again Steve,
How about spectral series?
By this I do not mean the mathematical spectral decomposition theorem.
I mean emission/absorption spectral series.
Here there is a diminishing step size which eventually leads a quantized system to a continuum.
@Lavinia
What would happen if your exact continuous model predicted a state between two permitted quantized ones?
This subject is beginning to be studied further by the great and the ?good? so is certainly worth further discussion at PF.
Zeno's point may have been that infinity doesn't exist in reality and therefore that motion doesn't exist. It may have had had nothing to do with summability of series.
A line? Perhaps you mean, "sprinkle particles of graphite here and there on the fibers of a piece of paper. If you were to magnify your "line" you would find it full of gaping holes, and quite irregular.
This thread really brings home the distinction between a mathematician's view of the difference between math and physics; and a physicist's or engineer's view of that difference.
You can't draw anything with pencil and paper that deserves being called a line. I might call your attention to Weirstrass's everywhere-continuous but nowhere-differentiable function. Since a continuous function is one whose graph you can draw "without lifting your pencil from the paper," I'd like to see someone draw it!
Now I do take your point ... I can travel from point A to point B, hence motion must be possible. But that's why they call it Zeno's paradox. I can't travel from point A to point B because first I have to travel half the distance, etc. ... so I can't even get started.
So what is the physical resolution of this mystery?
Physically, there IS no mystery. Just walk from point A to point B. The mystery is why mathemeticians don't see it as Zeno's mistake as Hootenanny suggests.
To me Zeno's point was that physically there was a mystery - that is that there is apparent motion but that it can not actually occur. He therefore argued that it must be an illusion - I think.
Surely that's obvious by now?
The time taken to go from A to B is finite.
So that time is composed of an infinite number of steps. But each step is finite and diminishing.
It is purely because each step is diminishing sufficiently fast that the total remains finite.
We can show this mathematically with series theory, knowing that there are diminishing divergent series, eg the harmonic series
http://en.wikipedia.org/wiki/Divergent_series
But you were seeking a physical demonstration, what about my example?
So do you think that the argument that motion is an illusion is an argument worth spending time trying to resolve? You HAVE moved from point A to point B haven't you?
The way I was told it Zeno argued that motion was an illusion because it was conceptually contradictory. Your point of view seems to deny the possibility of illusions and seems to assert that experience is irrational. I do not think Zeno would have found this point of view very relevant or correct.
If you believe that the world must make sense it seems that you must deal with this paradox.
Isn't 20 -20 hindsight wonderful?
I don't think the ancient Greeks had a theory of convergence for infinite series.
Zeno did the best he could at the time and pointed out an inconsistency in the then available theory and knowledge.
This is actually taking us away from the OP but I am labouring the point since the OP has done exactly the same with modern knowledge
Further, Professor Majid has offered this as a possible cause /reason for the current irreconciliability of relativity and quantum theory. A worthy prize indeed if such can be achieved.
So I repeat this is a subject worth serious adult consideration, rather than flippant dismissal.
Just to show why I think convergent series was not at all on Zenos' mind but rather the proof that motion was illusory consider his second argument. An archer shoots an arrow and we watch it sail through the sky and hit its target. But at each point in time it is just where it is. So how can it be moving?
Studiot said:
Hello again Steve,
Regrettably I'm out of my physics depth at this point. Is this something that's commonly understood to reconcile Zeno's paradox?
Atomic emission spectra was one of the founding physical phenomena which lead to the quantum theory.
Essentially light emissions from stimulated atoms does not form a continuous spectrum of frequencies.
Light appears as a series of spectral lines at specific frequencies, with darkness in between.
The frequency spacing between these lines forms a diminishing series, eventually culminating in a continuous spectrum of emitted light frequencies above a certain value.
For example
http://en.wikipedia.org/wiki/Balmer_series
Now the interesting thing is that the mathematical solution of the continuous quantum equations leads to the same specific frequencies and forbids the dark regions. They also predict the diminishing step size and the continuous region. Further these equations are differential equations.
So this takes us back to the OP and the link between quantisation and calculus.
Huh? I don't get that at all. If I want to go from point A to point B, I just do it. I don't see any paradox. What is it about that that you think doesn't make sense?
lavinia said:
Your point of view seems to ... assert that experience is irrational.
Say WHAT? If I want to move from point A to point B, I just do it. What is it about that that you find irrational? I certainly don't find anything irrational about it.
While I understand your argument you are ignoring Zeno's whole point. You are saying if it happens it makes sense. Ok so a mirage then is real - it is not a mirage. Anything is real. Fine. But Zeno's point, and the point of many others is that there has to be rational consistency to the world. You say no - it is what it is. That is a different point and is irrelevant to solving the problem of motion.
No, I understand your point as well. What I was objecting to was your statement that I had asserted that experience is irrational when I had said no such thing.
I DO understand that there is worth to pursuing the kind of things behind Zeno's paradox, what I object to is the phrasing that says Zeno's paradox shows that motion is not real.
NO, Zeno's paradox clearly CANNOT show that motion is not real because motion IS real, so the phrasing should be more like "hey, we have this really nifty, clever way of looking at motion that seems to make it not possible and since it so clearly IS possible, we need to figure out what it is about our way of looking at it that leads to such an absurd conclusion". An it seems to me that exactly that has been DONE a couple of times already in this thread. Zeno had the math wrong. It's Zeno's mistake.
micromass said:
But why are our approximations so good? We don't know. This is (in my opinion) the greatest mystery of the universe. Why is math so good in approximating the universal laws?
I've always thought that this was a result of a convenient choice of notation and measurement. Our units, although naturally chosen, are still human constructs. If we keep building on these constructs to develop things like calculus, then of course we will well-approximate physical phenomena -- these physical phenomena are "measured" by human constructed units anyway.
Exactly. It was not a mistake back then. It was a puzzle. We do have such a notion now. Continuing to harp on Zeno's paradoxes of motion as anything but a lack of understanding of regarding the nature of the reals and the nature of science on the part of those ancient Greeks is a modern mistake.
Another way to look at it: At this site we no longer accept threads that try to argue that [itex]0.999\cdots\ne1[/itex]. Zeno's paradox is exactly the same thing, just in base 2: [itex]0.111_2\cdots\equiv 1[/itex].
Yet another way to look at it is a failing to understand how science works. In a perhaps too condensed a nutshell, mathematicians try to prove mathematical theorems while scientists try to disprove scientific theories. There are (at least) two ways to disprove a scientific theory. One way is to attack the logic that underlies the theory. Scientific theories must be logically sound, mathematically correct. A hypothesis that doesn't add up is invalid.
Another way is to attack a scientific theory is from an angle that does not necessarily apply to mathematics. Just because the underlying math of some scientific theory is absolutely beautiful and perfectly sound does not mean the theory is correct. Science has to describe the real world. A failure here (observing just one black swan, for example) means the theory is false or is of limited applicability. This connection with reality can never be proven to be true. Science depends on observation. While one observation can prove that a theory is incorrect, mountains of observation do not prove that a theory is correct. It is merely confirming evidence.
That one black swan rule does allow us to rule out a lot, including Zeno's paradoxes of motion. The seemingly naive answer, I just walked from A to B, does it in.
This is exactly what I was talking about above. There is no need for a physical solution to Zeno's paradoxes of motion. I just walked from A to B. End of story. Zeno's dichotomy fails to comport with reality. It is a falsified scientific theory. Discussing it from a scientific point of view is pointless.
Zeno did not have the math wrong. He was not talking about convergence of series at all.
If you believe that Zeno was right, then good luck getting from point A to point B.
