Imaginary part of complex number (first post)
The discussion focuses on finding the imaginary part of the complex expression C = A * e^(-i * wt) * sin(k * x), where A, w, t, k, and x are real numbers. Using Euler's formula, e^(-i * wt) is expressed as cos(wt) - i * sin(wt), leading to the final expressions for the real and imaginary parts: Re(C) = A * cos(wt) * sin(k * x) and Im(C) = -A * sin(wt) * sin(k * x). The imaginary part is definitively identified as -A * sin(wt) * sin(k * x).
  • Understanding of complex numbers and their properties
  • Familiarity with Euler's formula, e^(iθ) = cos(θ) + i sin(θ)
  • Basic knowledge of trigonometric functions and their applications
  • Experience with algebraic manipulation and distributive property
  • Study the applications of Euler's formula in electrical engineering
  • Learn about complex number representations in physics
  • Explore the implications of imaginary numbers in wave functions
  • Investigate the use of complex numbers in signal processing
Students in physics or engineering, mathematicians dealing with complex analysis, and anyone interested in the applications of complex numbers in real-world scenarios.
bfed
C=A*e^(-i*wt)*sin(k*x); A,w,t,k,x are real numbers. Find imaginary part.
Im(C)=cos(wt)-i*sin(wt)
Use Euler's formula e = cos(θ) + i sin(θ), and then simplify the resulting expression. The coefficient of i will be the imaginary part of C.
so then the imaginary party would be sin(wt)?
and what happens to the A in the function?
No, that's not right. What is the expression you got after using Euler's formula to expand C?
e^(-iwt)=cos(wt)-i*sin(wt) is how I think to the Euler formula...
then do i substitute it back into the original expression?
Yes, substitue it back into the original expression, and then expand out the brackets using the distributive law of multiplication, i.e. A(B + C) = AB + AC.
Then you will have an expression of the form C = R + iI, and I is the imaginary part of C.
so...
C=A*cos(wt)*sin(kx)-i*A*sin(wt)*sin(kx)
Re(C)=A*cos(wt)*sin(kx)
and
Im(C)=-A*sin(wt)*sin(kx)
is this the proper solution?
And thanks dx
Yep, that's right.
good stuff much appreciated dx
  • · Replies 27 ·
